02-08-2019 05:47 AM - edited 03-08-2019 05:17 PM
Hi dear,
I try to configure Cisco StackWise Virtual in switch 9407r but StackWise command are not support.
Below you find show version command output :
Switch#sh version
Cisco IOS XE Software, Version 16.09.02
Cisco IOS Software [Fuji], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.9.2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Mon 05-Nov-18 19:32 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.6.2r[FC1], RELEASE SOFTWARE (P)
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-essentials Smart License network-essentials
None Subscription Smart License None
02-08-2019 07:02 AM
02-08-2019 07:06 AM
Contact Local Cisco Partner can able to help you.
=====️ Preenayamo Vasudevam ️=====
02-08-2019 07:22 AM
02-08-2019 07:27 AM
02-08-2019 07:42 AM
If you have License you are right to use.
02-08-2019 07:46 AM
