11-05-2012 04:14 AM - edited 03-07-2019 09:51 AM
Hi Experts,
I have some confusion with holding Mode button with cisco 2960/3560 switchs.
I read out many forums and articles but where things are unclear.
somewhere given 3 seconds and somewhere it is given 7 or 10 seconds.
Qus1) What is exact time to press/hold Mode button to perform two given below tasks:
A. Password recovery ( as per my knowledge 3 secs) Right or Wrong ?
Would switch configuration (startup + running) be safe
after password recovery? Yes or No
B. Factory default (as per my knowledge 10 secs) Right or Wrong ?
I am afraid, bcoz if i press mode button more than 3 seconds then
it will remove whole configuration from cisco switch. Yes or No
Qus2) I want to recover password of catalyst 2960/3560 switch without
loosing Start/Run configuration. this is my main concern.
plz tell me how to do this, what will be the Mode buttom hold time
in seconds ?
Qus3) What does mean of this line
"If password recovery mechanism is disabled in switch
then you will lose all the config".
This Sentence was given on this forum url
https://supportforums.cisco.com/thread/140848
KS
Solved! Go to Solution.
11-06-2012 12:29 AM
Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch.
Use the following terminal settings:
Bits per second (baud): 9600
Data bits: 8
Parity: None
Stop bits: 1
Flow Control: Xon/Xoff
Note: For additional information on cabling and connecting a terminal to the console port, refer to Connecting a Terminal to the Console Port on Catalyst Switches.
Unplug the power cable.
Power the switch and bring it to the switch: prompt:
For 2900XL, 3500XL, 2940, 2950, 2960, 2970, 3550, 3560, and 3750 series switches, do this:
Hold down the mode button located on the left side of the front panel, while you reconnect the power cable to the switch.
| 2960, 2970 | Release the Mode button when the SYST LED blinks amber and then turns solid green. When you release the Mode button, the SYST LED blinks green. |
| 3560, 3750 | Release the Mode button after approximately 15 seconds when the SYST LED turns solid green. When you release the Mode button, the SYST LED blinks green. |
The system has been interrupted prior to initializing the flash file system to finish
loading the operating system software:
flash_init
load_helper
boot
switch:
Issue the flash_init command.
switch: flash_init Initializing Flash... flashfs[0]: 143 files, 4 directories flashfs[0]: 0 orphaned files, 0 orphaned directories flashfs[0]: Total bytes: 3612672 flashfs[0]: Bytes used: 2729472 flashfs[0]: Bytes available: 883200 flashfs[0]: flashfs fsck took 86 seconds ....done Initializing Flash. Boot Sector Filesystem (bs:) installed, fsid: 3 Parameter Block Filesystem (pb:) installed, fsid: 4 switch: !--- This output is from a 2900XL switch. Output from !--- other switches will vary slightly.
Issue the load_helper command.
switch: load_helper switch:
Issue the dir flash: command.
Note: Make sure to type a colon ":" after the dir flash.
The switch file system is displayed:
switch: dir flash: Directory of flash:/ 2 -rwx 1803357c3500xl-c3h2s-mz.120-5.WC7.bin !--- This is the current version of software. 4 -rwx 1131 config.text !--- This is the configuration file. 5 -rwx 109 info 6 -rwx 389 env_vars 7 drwx 640 html 18 -rwx 109 info.ver 403968 bytes available (3208704 bytes used) switch: !--- This output is from a 3500XL switch. Output from !--- other switches will vary slightly.
Type rename flash:config.text flash:config.old to rename the configuration file.
switch: rename flash:config.text flash:config.old switch: !--- The config.text file contains the password !--- definition.
Issue the boot command to boot the system.
switch: boot Loading "flash:c3500xl-c3h2s-mz.120-5.WC7.bin"...############################### ################################################################################ ###################################################################### File "flash:c3500xl-c3h2s-mz.120-5.WC7.bin" uncompressed and installed, entry po int: 0x3000 executing... !--- Output suppressed. !--- This output is from a 3500XL switch. Output from other switches !--- will vary slightly.
Enter "n" at the prompt to abort the initial configuration dialog.
--- System Configuration Dialog --- At any point you may enter a question mark '?' for help. Use ctrl-c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !--- Type "n" for no. Press RETURN to get started. !--- Press Return or Enter. Switch> !--- The Switch> prompt is displayed.
At the switch prompt, type en to enter enable mode.
Switch>en Switch#
For password recovery
Type rename flash:config.old flash:config.text to rename the configuration file with its original name.
Switch#rename flash:config.old flash:config.text Destination filename [config.text] !--- Press Return or Enter. Switch#
Copy the configuration file into memory.
Switch#copy flash:config.text system:running-config Destination filename [running-config]? !--- Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1#
The configuration file is now reloaded.
Overwrite the current passwords that you do not know. Choose a strong password with at least one capital letter, one number, and one special character.
Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords.
Sw1# conf t !--- To overwrite existing secret password Sw1(config)#enable secret!--- To overwrite existing enable password Sw1(config)#enable password !--- To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config-line)#password Sw1(config-line)#login !--- To overwrite existing console password Sw1(config-line)#line con 0 Sw1(config-line)#password
Write the running configuration to the configuration file with the write memory command.
Sw1#write memory Building configuration... [OK] Sw1#
For Factory reset:
dont give below command for factory reset
do copy running config to flash,
Switch#copy running-config flash:
[OK]
Switch#copy running-config startup-config
Destination filename [startup-config]?
[OK]
Go through the below link for more info
Please rate the helpful posts.
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
03-08-2013 09:42 PM
Actually i am bit confused with Mode button, everyone saying that Mode button is used for Rommon Mode Only, but when i hold Mode button for more than 3 seconds i.e around 10 seconds then it removes whole switch configuration. why ?
Why? Why what? Like I've said before, I don't understand what you are trying to do.
Why, if you hold the Mode button for 3 seconds you go into ROMmon? And why, if you hold the Mode button why it RENAMES the configuration file to "config.text.rename"?
The answer to your questions are: That's how it's designed.
Besides, if you want to do password-recovery, you don't count the number of seconds. You look at what the console is showing.
11-05-2012 09:24 AM
"Is there any Cisco professional " is a very cool question!! For the first instead the mode button is only sending the switch in ROMMON and nothing else. From there on there is the flash initialisation and the rest of the procedure to do. Apart from the method used(ctrl+break in the first 60 seconds in some switches vs. mode button in others), you need to keep in mind you are going to manipulate the registers. Hence the first step will remain entering in ROMMON.
Question two:
Once you skip the password you need a simple
Copy start run
As first command from privilege mode and a write mem only after verifying your running config is the one you want(show run).
Question three:
Some environments require a very high level of security, nearly paranoic.. For that reason you can disable the possibility to recover your password with
Conf t
No service password-recovery! Please check the command on the platform you are using ;)
In this case, you will be still able to access your switch but you will not be able to recover the old configuration.
Hope this clarifies
Take care
Alessio
11-05-2012 01:40 PM
You still can do password-recovery when you run that command.
11-06-2012 12:29 AM
Data bits: 8
Parity: None
Stop bits: 1
flash_init
load_helper
boot
switch:
Switch>en Switch#
For Factory reset:
[OK]
[OK]
Thanveer
01-06-2017 03:18 AM
Hi all cisco professors,
I have cisco 2960 switch and I forget my password then I follow all the steps but I got only these two commands;
flash_init
boot
switch:
but I couldn't get load_helper, I did flash_init then it is initialize then I typed load_helper but it says "not recognize command" then I type boot but it says foot failure so how can I recover my password for cisco 2960 switch? can anyone help to me?
BINOD
05-22-2018 08:44 AM
Hello Mohammed ,
i know this is an old post but i am having a similar issue. it seems that former engineer mistakenly deleted the image file as there is no file in the flash directory except the environmental variable. The config is shown below
switch: ?
? -- Present list of available commands
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
load_helper -- Load and initialize a helper image
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_param -- Set system parameters in flash
trap -- Cause a software breakpoint to occur
type -- Concatenate (type) file(s)
-- MORE --
unset -- Unset one or more environment variables
version -- Display boot loader version
switch: dir
List of filesystems currently registered:
flash[0]: (read-write)
xmodem[1]: (read-only)
null[2]: (read-write)
bs[3]: (read-only)
switch: dir flash:
3 -rwx 30 <date> env_vars
7739904 bytes available (1536 bytes used)
switch:
could you assist ?
02-23-2013 10:11 AM
For 2960
For 3560
A. Password recovery ( as per my knowledge 3 secs) Correct or Wrong ?
would switch configuration (startup + running)
STARTUP-CONFIG will be safe.
B. Factory default (as per my knowledge 10 secs) Correct or Wrong ?
For Factory default you have to use write erasse command. If this is the scene then any body can hold mode button and can do his work easily :P.
Mode button is for Rommon Mode Only
in seconds ?
You can follow Cisco Documented Steps using below link
If u have disabled passwordy recovery by using following command
no service password-recovery
Then you access to rommon mode will be disabled to view configuration file or change setting etc.
If this is the case it will ask u this
Would you like to reset the system back to the default configuration (y/n)?
03-08-2013 01:50 PM
Hello Experts,
plz show interest and help me out with exact answers.....
KS
03-08-2013 05:12 PM
I don't know what you want. Do you want an answer "you want to hear" or do you want an answer that alot of Cisco expert users have SUCCESSFULLY used?
The easiest way for you to know and learn is get a switch, put a simple username and password and experiment.
03-08-2013 09:34 PM
KS
03-08-2013 09:42 PM
04-13-2015 10:49 AM
I have a Catalyst 2960 Series SI switch I don´t have the password for. I will try the suggested options and let you know how it works.
I have 2 subnets. Switch connects fine to one and provides service in all ports. To the second network it won´t complete connection (port led remains amber).
Will I better off with modifying a specific parameter or to factory-reset and enable service for any network I connect the switch to?
Thanks in advance.
04-13-2015 02:25 PM
I was able to reset password.
I know this is a long inactive discussion.
Will check / open other thread to consult the 2 subnet problem.
Thank you.
11-21-2016 12:02 AM
Its really helpful.
11-11-2017 12:21 AM
Please check below mention quick step to recover switch password and configuration but it is recommended to follow complete process
http://aqlearningcenter.blogspot.com/2017/11/2960-switch-password-recovery-quick.html
Hope document helpful for you
Qasim
