Switch Image GNS 3 not load Console
hfakoor222
No matter which switch image I am using the console window hangs. I've tried increasing the memory.
and in this case i am using a layer 3 image
try restarting PC. this can be a glitch. or try to use another console using right click > custom console > standalone putty
Good luck
KB
where did you get that image, L3-ADVENTERPRISE9-15.5.2T.bin ? Or the other images you are trying ? There are only a few that work with GNS3.I think the below still applies:
--> For switching, you can use an IOU L2 binary image, or an IOSvL2 virtual disk image with Qemu.
Martin L
this is gns3 issue to be asked on their forum; I know there are 2 ways to run gns3: stand-alone and server, which is recommended. There are limitation regarding using images and image licenses.  I think you are almost there.
Regards, ML
**Please Rate All Helpful Responses **
