Cisco Switch 2960x not resetting to default by pressing mode button.
razeev rohilla
Hi All,
i have a cisco switch 2960x, which i want to factory reset. i remain pressed mode button for 30-60 Second while powering on but switch not goes to ROMMON Mode. However it shows password recovery mechanism is enable. but it every time load previous configuration.
Kindly advise and support.
7 Replies 7
Mark Elsen
  - Attach a console to the device , and see what happens when you try to factory reset , if after 3 seconds you get a prompt (e.g.) , you can also try  : flash_init
 M.
noted, will do.
Hello
atrach a console cable before you power up switch-
Then power on switch whilst you de-press the mode button -
wait for the sys light to flash and let go-
At console prompt - flash_init
delete flash:config.text
delete flash:vlan.dat
Boot
Kind Regards
Paul
hi Paul,
i tried this many times but never observe behavior of SYS Led, will observe and revert back to you.
jimairwalk007
Hi, I'm not sure if this will work but can you try command 'write erase' then 'reload'?
Cli command will work after entering the switch, but the questions is this, I am not able to enter into the switch.
shamrozakram18
The Cisco Switch 2960x sometimes does not reset to its default settings by simply pressing the mode button. This can be frustrating for users who want to restore the switch to its factory configuration. In such cases, it is recommended to try alternative methods, such as using the console cable and accessing the switch's command-line interface (CLI), or utilizing the password recovery process provided by Cisco. These approaches can help troubleshoot and resolve the issue, allowing users to successfully reset the Cisco Switch 2960x to its default state.
