Cisco Switch 3560 not booting
Abbasi
I have installed a new IOS image but it's not loading in normal mode..!! there was the same issue on the previous iOS.
What could the problem? Anyone can help..?
switch: boot flash:c3560-ipbasek9-mz.122-55.SE12.bin
Loading "flash:c3560-ipbasek9-mz.122-55.SE12.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:c3560-ipbasek9-mz.122-55.SE12.bin" uncompressed and installed, entry point: 0x1000000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(55)SE12, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 28-Sep-17 02:04 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02D00000
Initializing flashfs...
flashfs[1]: 1 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 11776512
flashfs[1]: Bytes available: 4222464
flashfs[1]: flashfs fsck took 1 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Checking for Bootloader upgrade.. not needed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Waiting for Port download...Complete
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3560-24PS (PowerPC405) processor (revision S0) with 131072K bytes of memory.
Processor board ID FDO1310X1WZ
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:24:F7:E7:32:80
Motherboard assembly number : 73-9673-11
Power supply part number : 341-0029-05
Motherboard serial number : FDO13100H1W
Power supply serial number : DTN130440K5
Model revision number : S0
Motherboard revision number : A0
Model number : WS-C3560-24PS-S
System serial number : FDO1310X1WZ
Top Assembly Part Number : 800-25861-05
Top Assembly Revision Number : D0
Version ID : V07
CLEI Code Number : COMUY10ARA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C3560-24PS 12.2(55)SE12 C3560-IPBASEK9-M
6 Replies 6
marce1000
   - Try to boot a similar image from USB , If the device don't have a usb you have to use TFTP server (using the tftpdnld ROMmon command recovery) in order to load a (new) image for the device.
 M.
@marce1000
I format flash and then loaded a new image through teraterm(tftp), but its not booting completely.
Keep hanging after the following message while booting iOS...
 - A hardware problem could be involved : power down the switch and power up again with the console ready. Look at the power up sequence and check for errors. If still not resolved then try a factory reset
 M
@Abbasi
 You did not show what ´s wrong. The logs show an image being uncompressed and installed.  What the prompt you get after that?
@Flavio Miranda
Keep hanging after the following message while booting iOS... I tried to restart the switch multiple times but it's freezing at the same point.
Leo Laohoo
Use a different computer.
The switch's console port is having an issue.
