Cisco Switch 3850-48U-L Error on reload
Alex1962
After issuing "reload" command switch produced following information:
umount: /proc/fs/nfsd: not mounted
Unmounting ng3k filesystems...
Unmounted /dev/sda3...
Warning! - some ng3k filesystems may not have unmounted cleanly...
Is these messages indicate on some kind of problem. Is it possible to fix it?
18 Replies 18
Leo Laohoo
What firmware is the switch currently on?
Alex1962
Sorry, I should post that in my original question: switch running software version 03.06.06E in INSTALL mode
If this switch is not in production, I would not worry because if the firmware has gone into a fault, there are many ways to put the firmware back into the switch.
Personally, I have have seen this once before and I did not encounter any problems.
Alex1962
Well, it is not in production yet. I want to put this switch in production but would like to clear up warnings. Any help to clear this up?
Alex1962
Step I already tried:
Upgrade to 3.6.8 - same warning
Emergency-install and factory reset - same warning
I think the error messages are fine.
marce1000
 - Use  https://software.cisco.com/download/home/284455424/type/282046477/release/Gibraltar-16.12.8 , if applicable , check if that can help ,
 M.
balaji.bandi
what command did you use to upgrade?
Can you post the complete boot message here also what is the current version before you upgrade to the latest?
BB
Alex1962
The original version was 3.3.5. I did emergency-install from usb with 3.6.8 - got message on reload:
 Warning! - some ng3k filesystems may not have unmounted cleanly...,
then erase startup and mode button to get factory reset, then I did basic configuration - still same warning on reload.
After that I did emergency-install from usb with 3.6.6 - same error message.
Then I convert from INSTALL to BUNDLE with same 3.6.6 - same error message
Then I convert from BUNDLE to INSTALL with same 3.6.6 - same error message
Here is full reload/boot:
Switch#reload
<Sun Feb 12 21:38:48 2023> Message from sysmgr: Reason Code:[3] Reset Reason:Reset/Reload requested by [stack-manager]. [Reload command]
Please stand by while rebooting the system...
Restarting system.
Booting...Initializing RAM +++++++@@@@@@@@...++++++++++++++++++++++++++++++++
Base ethernet MAC Address: 6c:99:89:9b:6d:80
Interface GE 0 link down***ERROR: PHY link is down
Initializing Flash...
flashfs[7]: 0 files, 1 directories
flashfs[7]: 0 orphaned files, 0 orphaned directories
flashfs[7]: Total bytes: 6784000
flashfs[7]: Bytes used: 1024
flashfs[7]: Bytes available: 6782976
flashfs[7]: flashfs fsck took 1 seconds....done Initializing Flash.
Getting rest of image
Reading full image into memory....done
Reading full base package into memory...: done = 83293932
Nova Bundle Image
Kernel Address : 0x6042d34c
Kernel Size : 0x41852f/4293935
Initramfs Address : 0x6084587c
Initramfs Size : 0xe7766d/15169133
Compression Format: .mzip
Bootable image at @ ram:0x6042d34c
Bootable image segment 0 address range [0x81100000, 0x82140000] is in range [0x80180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 380
Loading Linux kernel with entry point 0x8166a600 ...
Bootloader: Done loading app on core_mask: 0xf
### Launching Linux Kernel (flags = 0x5)
All packages are Digitally Signed
Starting System Services
FIPS(NGWC): Flash Key Check : Begin
FIPS(NGWC): Flash Key Check : End, Not Found, FIPS Mode Not Enabled
MCU type = 0 and image name is main_mcu_ucode_bundle_6_2_0.tar
Final tar file: main_mcu_ucode_bundle_6_2_0.tar
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.06.06E RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sat 17-Dec-16 00:22 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3850-48U (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FOC1825U14K
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of at webui:.
Base Ethernet MAC Address : 6c:99:89:9b:6d:80
Motherboard Assembly Number : 73-14983-06
Motherboard Serial Number : FOC18XXXXXX
Model Revision Number : E0
Motherboard Revision Number : A0
Model Number : WS-C3850-48U
System Serial Number : FOC18XXXXXX
Press RETURN to get started!
Alex1962
Another question I have - Why switch check for FIPS file twice?
This means the IOS loaded success fully, or do you have any issue still ?
still issue - we have asked what commands you used to upgrade  ?
BB
Alex1962
My issue:
The command I used to upgrade:
Emergency-install
Can you help to clear "Warning"
    - The warning should be considered minor and unimportant ,
 M.
Alex1962
I don't want to deploy switch in production with issues. What version you are using and do you see this "Warning"?
