Cisco Switch Blocking or Disabling Ports
dkujat
8 Replies 8
dkujat
Sorry the post didn't load, but my cisco switch keeps disabling ports during updates to the server. We get quarterly updates and ports go offline. Is there another way to stop this action from happening? We have a Cisco C-3850-nm-4-1G
The ports going shutdown mode, then what is the Logs show ? what is the reason of port shutdown
what is the configuration applied on that port
show run interface x/x
BB
So the Cisco is the switch for our Bosch CCTV and when we push updates to the server my CCTV ports keep shutting down each time.
Do you config any broadcast storm threshold?
I'm not an expert at Cisco, so I don't know what you mean. I'm looking to know if I will have to use a PuTTy each time updates occur or if there is a feature we can turn off.
You can check by
Show interface status
See if the port is go to errdisable
For strom check this
https://community.cisco.com/t5/switching/where-to-configure-storm-control/td-p/3414884
If you are not IT Expert - Contact your  IT network people to help you.  Until provide information not much help you get here.
BB
Can you more elaborate please
