WS-X4712-SFP+E compatibility with 4510R+E core switch with Sup 8-E
PaulOstaszewski
I've done some digging on this and i keep finding mixed data.  Some sites say its compatible but cisco's site says its not.
Can someone tell me if the WS-X4712-SFP+E line card is compatible with the 4510R+E core switch running the WS-X45-SUP8-E supervisor?  Its running old code (never upgraded since it was installed in 2015) cat4500es8-universalk9.SPA.03.06.04.E.152-2.E4.bin
Please let me know if you need any additional information.
5 Replies 5
Reza Sharifi
According to Table 1 in this link from 2016, it is not supported.
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/catalyst-4500-series-line-cards/product_data_sheet0900aecd802109ea.html
Cisco Catalyst 4500 47xx E-Series Line Cards
Note: WS-X4712-SFP+E and WS-X4748-12X48U+E are not supported on 4507R-E and 4510R-E
I just found this link, which from the Supervisor 8-E standpoint, it says that it is compatible https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-series-switches/data_sheet_c78-728191.html
Supported Cisco Catalyst 4500E Series Line Cards and Modules
  •    WS-X4748-12X48U+E: Cisco Catalyst 4500E Series 48-Port (RJ-45) Line Card with 12 Multigigabit Ports and 36 10/100/1000 Ports with 802.3af PoE, 802.3at PoEP, and UPOE
  •    WS-X4748-UPOE+E: Cisco Catalyst 4500E Series, 48-port 802.3af PoE, 802.3at PoEP, and UPOE 10/100/1000
  •    WS-X4748-RJ45-E: Cisco Catalyst 4500E Series, 48-port 10/100/1000 (RJ-45)
  •    WS-X4748-RJ45V+E: Cisco Catalyst 4500E Series, 48-port PoE 802.3at 10/100/1000 (RJ-45)
  •    WS-X4712-SFP+E: Cisco Catalyst 4500E Series, 12-port 10 Gigabit Ethernet (SFP+)
  •    WS-X4748-SFP-E: Cisco Catalyst 4500E Series, 48 port Gigabit Ethernet Fiber Line Card
  •    WS-X4724-SFP-E: Cisco Catalyst 4500E Series, 24 port Gigabit Ethernet Fiber Line Card
  •    WS-X4712-SFP-E: Cisco Catalyst 4500E Series, 12 port Gigabit Ethernet Fiber Line Card
  •    WS-X4648-RJ45V-E: Cisco Catalyst 4500E Series, 48-port 802.3af PoE 10/100/1000 (RJ-45)
  •    WS-X4648-RJ45V+E: Cisco Catalyst 4500E Series, 48-port Premium PoE 10/100/1000 (RJ-45)
  •    WS-X4648-RJ45-E: Cisco Catalyst 4500E Series, 48-port 10/100/1000 (RJ-45)
  •    WS-X4640-CSFP-E: Cisco catalyst 4500E Series, 40- and 80-port SFP/CSFP Gigabit Ethernet line card
  •    WS-X4606-X2-E: Cisco Catalyst 4500E Series, 6-port 10 Gigabit Ethernet (X2)
  •    WS-X4624-SFP-E: Cisco Catalyst 4500E Series, 24-port Gigabit Ethernet (SFP)
  •    WS-X4612-SFP-E: Cisco Catalyst 4500E Series 12-port Gigabit Ethernet (SFP)
  •    CVR-X2-SFP: Twin gigabit converter module
The link to the document you posted is from 2018, which is newer than the one I posted, but you may still want to talk to your Cisco SE or sales guy to be sure because Sup-8 is end-of-life and sale.
Yup, appears true for the -E chassis.
OP notes having a +E chassis.
I recall the 7R-E and 10R-E support 24 Gbps per slot, while the 7R+E and 10R+E support 48 Gbps per slot.
Figure 3     WS-X4712-SFP+E Cisco Catalyst 4500E Series 12-Port 10 Gigabit Ethernet (SFP+)
WS-X4712-SFP+E:
●   48 gigabits per-slot capacity
●   Bandwidth is allocated across four 3-port groups, providing 12 Gbps per port group (2.5:1)
●   Up to 12 ports 10GE SFP+ (10GBASE-R) or 12 ports GE SFP (1GBASE-X)
●   SFP+ and SFP can be used simultaneously on the same line card without any restrictions
●   Cisco IOS® XE Release 3.1.0SG or later
●   IEEE 802.1AE and Cisco TrustSec capability in hardware
●   L2-4 Jumbo Frame support (up to 9216 bytes)
●   Enterprise and commercial: designed for high-speed backbone and switch-to-switch applications
●   Service provider: 10GE/GE mix aggregation for DSLAM/PON/mobile data backhaul
●   WS-X4712-SFP+E is not supported on 4507R-E and 4510R-E chassis
I believe it would be fine with a sup8 in the +E chassis.
The cores are running older code cat4500es8-universalk9.SPA.03.06.04.E.152-2.E4.bin which I believe translates to 3.6.4(MD).
I looked on the support downloads for the SUP 8-E and see that cat4500es8-universalk9.SPA.03.06.04.E.152-2.E4.bin is under 3.6.4(MD).  Its safe to say that I am running newer code than the minimum required 3.1.0SG, correct?
