Cisco Switch C9200-48T stuck in ROMMON mode
tomipandaziev
I have a cisco switch C9200-48T and it cannot boot because there is no image on the switch. I tried with several proposals to transfer image but unsuccessfully, I tried also with Xmodem but it seems that flash is read only.
Here is what inputs I have:
switch: dir
usage:
dir <path-to-directory>
supported filesystem(s):
flash: ro flash
usbflash0: rw front-panel USB 0
usbflash1: rw front-panel USB 1
switch: dir flash:
Attributes Size Name
switch: dir usbflash0:
media drive "usbflash0:" not present.
Error[11]: Failed to open directory!
switch: dir usbflash1:
media drive "usbflash1:" not present.
switch: copy xmodem: flash:cat9k_lite_iosxe.17.06.04.SPA.bin
Unsupported destination device/filesystem.
@tomipandaziev
Try reformatting the drive to the correct file system and/or trying a different USB flash drive to see if the issue persists.
Best regards
16 Replies 16
M02@rt37
Hello @tomipandaziev
You can boot the Cisco switch from a USB storage device while in ROMMON mode.
Insert the USB storage device containing the IOS image file into one of the USB ports on the switch.
Verify that thSet the boot variable to point to the IOS image file on the USB storage device using the "set" command:
rommon 1 > set BOOT usbflash0:cat9k_lite_iosxe.17.06.04.SPA.bin
Make sure to replace "cat9k_lite_iosxe.17.06.04.SPA.bin" with the name of the IOS image file on your USB storage device, and use the appropriate device name (e.g., "usbflash0:") for your USB storage device.
Issue the "boot" command to boot the switch using the IOS image file on the USB storage device:
rommon 2 > boot
Best regards
I share the result of my switch after applying this process
Switch#
Initializing Hardware...
System Bootstrap, Version 17.5.1r [FC4], RELEASE SOFTWARE (P)
Compiled Wed 01/06/2021 17:07:29 by rel
Current ROMMON image : Primary
C9200L-24P-4G platform with 2097152 Kbytes of main memory
WARNING: Bootable URL's in BOOT variable not found or exhausted.
Please check the ROMMON configuration or boot command usage.
D-HS- 0 System Volume Information
----A 473832423 cat9k_lite_iosxe.17.09.05.SPA.bin
----A 527146419 cat9k_lite_iosxe.17.06.05.SPA.bin
switch: set boot usbflash0:cat9k_lite_iosxe.17.09.05.SPA.bin
switch: boot usbflash0:cat9k_lite_iosxe.17.09.05.SPA.bin
boot: attempting to boot from [usbflash0:cat9k_lite_iosxe.17.09.05.SPA.bin]
boot: reading file cat9k_lite_iosxe.17.09.05.SPA.bin
ERROR: Integrity Check Failed
ERROR: failed to boot from usbflash0:cat9k_lite_iosxe.17.09.05.SPA.bin (Invalid Parameter)
switch:
Post the complete output to the ROMMON command of "set".
tomipandaziev
Thanks for replying, I got this when I try to execute "dev" command:
switch: dev
Error: command 'dev' not found. Use 'help' to list commands.
switch: help
arp Dump or Clear ARP Table
boot Load and boot an executable image
cat Display text content from a file
copy Copy a file
dir List filesystems or a directory on a filesystem path
help List command information
history Show command history
idprom Show idprom data
ping Ping use ICMP protocol to get an ICMP ECHO_RESPONSE from host
ping6 Ping use ICMP protocol to get an ICMP ECHO_RESPONSE from host
reset Reset entire system or a soft reload of the boot CPU core
set Set an environment variable value
unset Unsets an environment variable
version Show sboot version and runtime info
Do I need to enter some other mode and how ?
seems like your flash is in RO mode. check this thread to load switch rommon to configuration mode and then copy the IOS from USB or xmodem to flash. and set the boot path
https://community.cisco.com/t5/switching/changeing-flash-from-read-only-to-read-write/td-p/3739978
Good luck
KB
M02@rt37
OK @tomipandaziev
Copy the bin on the usb storage
Plug your usb on the front panel usb0
Replace the name's file by the correct one.
Then rommon 2> boot
Best regards
I get this:
switch: set BOOT usbflash0:cat9k_lite_iosxe.17.06.04.SPA.bin
switch: boot
boot: attempting to boot from [usbflash0:cat9k_lite_iosxe.17.06.04.SPA.bin]
boot: reading file cat9k_lite_iosxe.17.06.04.SPA.bin
boot: failed to load usbflash0:cat9k_lite_iosxe.17.06.04.SPA.bin
ERROR: failed to boot from usbflash0:cat9k_lite_iosxe.17.06.04.SPA.bin (Not Found)
Please wait while the system restarts.
I'm using USB(8GB) but shrink to 4GB and I have copy the bin file in it. Should I do it other way ?
@tomipandaziev
Usb is not detected. When plugged "dir" command on usbflash0: and usbflash1: give you something?
What is the filesystem of your usb? FAT32? NTFS?
Best regards
M02@rt37 @Kasun Bandara
The usb is FAT32, and this is what I get
switch: boot
@tomipandaziev
Turn off the switch
Plug the USB
Turn ON the switch ---- ROMMon mode
dir usbflash0? or 1?
Best regards
It's the same after restarting the switch, the USB is not showing..
@tomipandaziev
Best regards
I tried with another USB(32 GB) format it with FAT32 and now  I was able to boot it successfully
@tomipandaziev wrote:
The usb is FAT32
The USB needs to formatted in FAT16.
How many USB flash drives have you tried?  Find one that is <32 Gb and try again.
To put the firmware back into the switch, use:  "emergency-install usbflash0:cat9k_lite_iosxe.17.06.04.SPA.bin".
