cisco switch can ping svi and one host but not another on same vlan
ma4ctg
I have a Cisco 3850 switch with IP services.
Inter-vlan routing in configured.
My computer is on the default vlan (1).
I have an SVI for vlan 192.
My Cisco ASA is connected to an access port on the 3850 on port 48 and is on vlan 192.
I added another host with an IP in the same vlan and connected to port 47 which is in vlan 192 and the mode is access.
From my computer I can ping the SVI and the ASA but not the new host on port 47.
When logged into the switch, I can ping the SVI, ASA and the new host on port 47.
What am I missing?
25 Replies 25
post the full running configuration of your 3850 switch (sh run)...
version 16.9
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service compress-config
service call-home
service unsupported-transceiver
no platform punt-keepalive disable-kernel-core
hostname flmswitch1
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5
enable password 7
no aaa new-model
clock timezone EST -5 0
clock summer-time EDT recurring
switch 1 provision ws-c3850-48u
coap http enable
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
no destination transport-method email
ip routing
ip admission watch-list expiry-time 0
ip name-server 8.8.8.8
ip domain name bottomlinepros.com
ip device tracking probe auto-source
ip dhcp excluded-address 10.1.10.1 10.1.10.200
ip dhcp excluded-address 10.1.1.1 10.1.1.199
ip dhcp pool VLAN10
network 10.1.10.0 255.255.255.0
default-router 10.1.10.1
dns-server 8.8.8.8
ip dhcp pool VLAN1
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
dns-server 8.8.8.8
ipv6 neighbor tracking auto-source
crypto pki trustpoint TP-self-signed-3139843348
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3139843348
revocation-check none
rsakeypair TP-self-signed-3139843348
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki certificate chain TP-self-signed-3139843348
license boot level ipservicesk9
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
no errdisable detect cause gbic-invalid
username flmadmin privilege 15 password 7 dsdsa
username ctgadmin password 7 dsada
redundancy
mode sso
hw-switch switch 1 logging onboard message
vlan dot1q tag native
lldp run
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data, LOGGING
class-map match-any system-cpp-default
description Inter FED, EWLC control, EWLC data
class-map match-any system-cpp-police-sys-data
description Learning cache ovfl, High Rate App, Exception, EGR Exception, NFL SAMPLED DATA, RPF Failed
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
description Transit Traffic and MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-system-critical
description System Critical and Gold Pkt
policy-map system-cpp-policy
policy-map port_child_policy
class non-client-nrt-class
bandwidth remaining ratio 10
interface Port-channel20
switchport trunk allowed vlan 20
switchport mode trunk
interface Port-channel100
description Unifi
switchport trunk native vlan 100
switchport trunk allowed vlan 100
spanning-tree portfast disable
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
speed 1000
negotiation auto
interface GigabitEthernet1/0/1
switchport access vlan 10
switchport mode access
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
switchport access vlan 99
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
switchport voice vlan 80
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
channel-group 20 mode active
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
switchport access vlan 192
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
shutdown
interface GigabitEthernet1/1/2
shutdown
interface GigabitEthernet1/1/3
shutdown
interface GigabitEthernet1/1/4
shutdown
interface TenGigabitEthernet1/1/1
switchport trunk allowed vlan 1-500
spanning-tree portfast trunk
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
ip address 10.1.1.1 255.255.255.0
interface Vlan10
ip address 10.1.10.1 255.255.255.0
interface Vlan20
description NAS
ip address 10.1.20.1 255.255.255.0
interface Vlan30
description UCS
ip address 10.1.30.1 255.255.255.0
interface Vlan60
ip address 10.1.60.1 255.255.255.0
interface Vlan99
ip address 10.1.99.1 255.255.255.0
interface Vlan100
description Unifi
ip address 10.1.100.1 255.255.255.0
interface Vlan192
ip address 192.168.200.1 255.255.255.0
interface Vlan250
ip address 10.1.250.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.200.254
control-plane
service-policy input system-cpp-policy
line con 0
login local
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7 dasda
login local
transport input ssh
line vty 5 15
password 7 dsads
login local
transport input ssh
ntp master
ntp server time.nist.gov
mac address-table notification mac-move
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
end
does Vlan 192 actually exist on the switch (sh vlan) ?
balaji.bandi
This windows FW issue, disable on device Windows FW and test it. (if the FW disabled, check the Gateway settings ? is this point to FW or Switch SVI - post more information)
BB
I disabled Windows firewall but still CANNOT ping 192.168.200.253 (Port 47).
I CAN ping 192.168.200.1 (SVI) and 192.168.200.254 (ASA - Port 48).
My PC is on the default VLAN (1).
Default gateway of my PC is 10.1.1.1.
Here is the output of the tracert command output:
C:\Users\admin>tracert 192.168.200.1
Tracing route to 192.168.200.1 over a maximum of 30 hops
1 7 ms 1 ms 6 ms 192.168.200.1
Trace complete.
C:\Users\admin>tracert 192.168.200.254
Tracing route to 192.168.200.254 over a maximum of 30 hops
1 1 ms 1 ms <1 ms 10.1.1.1
2 <1 ms <1 ms <1 ms 192.168.200.254
Trace complete.
C:\Users\admin>tracert 192.168.200.253
Tracing route to 192.168.200.253 over a maximum of 30 hops
1 3 ms 1 ms 3 ms 10.1.1.1
2 * * * Request timed out.
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 ^C
can 192.168.200.253 ping 192.168.200.1 and 10.1.1.1 ?
I cannot connect to .253. That is actually a pfSense firewall. I was able to connect to it when the IP address of the LAN interface was 10.1.1.70. I changed it to 192.168.200.253 and move it to port 47 which is on vlan 192 just like the ASA.
is ping (ICMP) allowed in the pfsense firewall rules ?
Can you post out put of ipconfig from device ?
post your network diagram how it look like
BB
Attached is a diagram of the network.
Here is the ipconfig output:
C:\Users\admin>ipconfig
Windows IP Configuration
Ethernet adapter Ethernet 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Ethernet adapter Ethernet:
Link-local IPv6 Address . . . . . : fe80::95d0:3e8e:f9b4:ceb7%17
IPv4 Address. . . . . . . . . . . : 10.1.1.45
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.1.1.1
Ethernet adapter VirtualBox Host-Only Network:
Link-local IPv6 Address . . . . . : fe80::dcf4:8897:189e:1319%9
IPv4 Address. . . . . . . . . . . : 192.168.56.1
Ethernet adapter Local Area Connection* 10:
Ethernet adapter vEthernet (Default Switch):
Link-local IPv6 Address . . . . . : fe80::ccff:7b1f:4982:a803%45
IPv4 Address. . . . . . . . . . . : 172.17.208.209
Subnet Mask . . . . . . . . . . . : 255.255.255.240
Thank you for the information :
your switch has routing pointing ASA :
Do you have route back to Switch from ASA and what is ASA  default route ?
BB
Yes, currently the ASA (.254) is being used as the firewall. I am trying to replace it with the pfSense since it has a GB interface.
Before I change the routing in the switch to point to the pfSense, I need to be able to access it on the .253 interface so I can manage it.
Right now, I am not able to ping or connect using the browser.
The current setup with the ASA is working.
Hope that makes sense.
Add  static entry in ASA/pfsense to minitigate the issue
BB
I'm sorry but I do not understand why I would need to do that since inter-vlan routing is happening in the switch.
I should be able to get to 192.168.200.253 without having to go to the ASA. The ASA is NOT doing LAN side routing.
That is how other connections are working.
Am I missing something?
