02-13-2021 04:28 AM
Hi Team,
IAs of now ether channel configuration running between 9300 and 9200 switch's and all are 1G Ethernet interface. Is it possible to add the additional 10G ofc ports in the same port-channel group. It means port channel configuration whether possible 1G interface and 10G ofc interface?
02-13-2021 04:32 AM
EtherChannel Rule #1: All ports must have the same speed.
02-13-2021 04:41 AM
Ok Then IS create a separate port channel group for 10G ofc interface between 9300 and 9200 switches? After that can we remove the 1G Ethernet interface..
Overall our plan is remove the existing Ethernet interface port channel and add the 10G ofc interface ether channel without downtime.. Is it possible? please suggest
02-13-2021 04:57 AM
Sure that is possible, make sure you make a plan correctly.
Prefered : ( you may see less convergence time)
1. build new Port-channel 10G in shutdown mode
2. when maintenance window, shutdown 1 GB PO and no shutdown 10GB ( depends on STP convergence configured it will be faster if you have Rapid STP will be faster)
Another method you can bring other Port-channel along with 1GB PO - this time one of the PO will go blocking mode (you need be big cautious here)
=====️ Preenayamo Vasudevam ️=====
02-13-2021 05:06 AM
Not possible.
When switching from 1 Gbps to 10 Gbps the EtherChannel will go DOWN and then up.
02-14-2021 09:56 PM
I recently did this from 10G to 40G and you will need to create a new group of port channels with new 10G interfaces and turn it off before connecting cables.
On your Downtime Windows, just do 10G up and 1G down. How long it will take to recover or should you maintain the interval between the UP and Down port channels will depend on your STP (if Layer 2) or other relevant protocol configurations. Make sure you know the behaviors of the LACP / PaGP protocol.
