- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-11-2022 12:52 AM
I have cisco SG220 series switches with 50 Port available for use before unknown incident happened. After the unknown incident happened 24 port consist of Gi1 - Gi12 and Gi25 - Gi36 can't be used.
when i attach a UTP cable with the other side connected to laptop to Port Gi1 Cisco Switch, the Port Gi1 LED not blinking. and when i type no shutdown in config-if mode the console return Port gi1: Invalid port id. But when the UTP cable is attached to Port Gi13 - 24 or Gi37 - Gi48 it's work normally. I'm already reset the switch to solve the problem but it's not work.
I want to diagnostic, troubleshoot, or another detailed information how to solve this. I'm already search in google with Cisco Switch SG220-50: Invalid port id keyword but that's not give me any clue.
Here is the console output:
Switch97A68B#conf t Switch97A68B(config)#int gi 1 Switch97A68B(config-if)#no shutdown Port gi1: Invalid port id Switch97A68B(config-if)#end Switch97A68B#show int gi1 GigabitEthernet1 is down Hardware is Gigabit Ethernet Auto-duplex, Auto-speed, media type is Copper flow-control is off back-pressure is enabled 0 packets input, 0 bytes, 0 throttles Received 0 broadcasts (0 multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 multicast, 0 pause input 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underrun 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 PAUSE output Switch97A68B#show interfaces status gi1 Port Name Status Vlan Duplex Speed Type gi1 notconnect 1 auto auto Copper Port Time Range Status ---- -------------------------------- -------- gi1
Solved! Go to Solution.
- Labels:
Other Switches
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-13-2022 08:01 PM
latest OS version is 1.2 series. try to upgrade OS to latest version and is the issue still occurs, better go to RMA hardware replacement.
Good luck
KB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-11-2022 01:28 AM
is this brand new installation or working one failed ? check the Logs while booting the device, you can see any hardware failure information.
Suggestion :
try to reset to factory and test it, other option try any latest firmware upgrade and test it.
Final :
Still issue, looks for hardware issue, SMB TAC for RMA.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-11-2022 05:53 PM
this switch already working for 2 years with no any issue before. sorry i don't know where to check the boot log, but this is the log from command show logging Cisco SG220-50 Log Output
I'm already do factory reset but it's still not working
would you like to give me the detail how to check the hardware issue ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-12-2022 12:06 PM
Looks for some some ASIC Port issue, raise an TAC for replacement
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-11-2022 01:40 AM
what is the OS version. better upgrade OS to latest version and check
Good luck
KB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-11-2022 05:57 PM
Here is the version
Switch97A68B#show version Cisco Sx220 Series Switch Software, Version 1.1.3.1, RELEASE SOFTWARE Copyright (c) 2014-2017 by Cisco Systems, Inc. Compiled Thu Apr 20 09:33:24 UTC 2017 ROM: Bootstrap program is Sx220 boot loader BOOTLDR: Sx220 Boot Loader Version 1.0.0.6, RELEASE SOFTWARE Compiled Jan 24 2014 - 14:44:30 Switch97A68B uptime is 2 days, 0 hours, 49 mins, 13 secs system image is image-1 Processor 700MHz , with 128M bytes of memory. 50 Gigabit Ethernet interfaces 0 Fast Ethernet interfaces 32M bytes of flash memory Base MAC Address : D4:AD:71:97:A6:8B IP Address : 192.168.25.111 Subnet Mask : 255.255.255.0 Model Number : SG220-50 Serial Number : DNI224606C8 PID : SG220-50-K9 VID : V03
Thanks for your help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-13-2022 08:01 PM
Good luck
KB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-14-2022 11:26 PM
the bad new is, i buy this switch with warranty excluded.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-12-2022 04:21 AM
it sounds like a hardware failure. As far as I recall, there are 4 port groups linked together on the motherboard: 1 -12, 13 -24, 25 - 36, 37 - 48. It sounds like two of these groups are experiencing a hardware failure.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-14-2022 11:23 PM
Hi Georg, thanks for your asnwer.
i think so. but i can't prove it and i just guess it by looking at the port group physically. would you like to give me some reference about the port group ?
