show Interfaces counters errors not showing Giants column
Magnets
Level 2
Level 2
Hello there,
I've been using 2900 series switches which show these counters
#show int count errors
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize OutDiscards
Port Single-Col Multi-Col Late-Col Excess-Col Carri-Sen Runts Giants
however we have a few 9200L-48P-4x running IOS XE 17.03.03
and when i do the same command i get
Where has the Giants column gone?
Magnets
Level 2
Level 2
this is the closest i got
sho interfaces | i Ethernet[0-9]| giants
It outputs the name of the port and the line with the giants on it.
I tried
sho interfaces | i Ethernet[0-9]| [^0] giants
which i thought would show line that didn't have 0 giants but it didn't work. so close enough.
7 Replies 7
Reza Sharifi
The 9200 should have it too. Can you post the output of "sh int tex/x/x"?
or
gix/x/x
Magnets
Level 2
Level 2
hmmmm, yes it's there, but not in the table. ugh. look at those giants.
GigabitEthernet2/0/40 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 6c13.xxxx.xxxx (bia xxxxxxxxxxxxx)
Description: XXXXXXXXXXXXXXXXXXXXXXX
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is on, output flow-control is unsupported
Last input 00:00:07, output 00:00:00, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 11000 bits/sec, 1 packets/sec
5 minute output rate 18000 bits/sec, 1 packets/sec
39650280 packets input, 14446407548 bytes, 0 no buffer
Received 596302 broadcasts (529843 multicasts)
0 runts, 114893 giants, 0 throttles
114893 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 529843 multicast, 0 pause input
57039520 packets output, 32862224608 bytes, 0 underruns
Output 1196810 broadcasts (0 multicasts)
0 output errors, 0 collisions, 3 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
That does help. Sorry, I'm a beginner at this, is there a regular expression i can use to make a table
sho int | inc giants
gives me the list but not the interface
Magnets
Level 2
Level 2
That does show the giants error.
but not in the error counter table. Is this a cisco bug or have they decided to put it only in the show interface command?
@Magnets wrote:
114893 input errors
`nough said.
"sh interfaces GigabitEthernet 2/0/40 | inc giant"
should show you something like this:
Magnets
Level 2
Level 2
Thanks Reza,
yup, that was the closest i got too. i'm lucky in that i know which interfaces i suspect will have the giants.
It was so much easier when they showed on the sho int count erro table.
Magnets
Level 2
Level 2
I tried
