Cisco Switch uplink connection issue
DG9
Dear Team,
We have two switch one side c9300 and other side CBS350 and we have attach dac cable from C9300 to CBS 350 switch as a uplink , but at c9300 side dac cable not detect , CBS 350 side showing detect .
so my question is , is it supported or not , this scenario ?
Waiting for your reply...
Thanks & Regards
DG
16 Replies 16
DG9
Dear Team,
at C9300 side showing error disable logs..
Thanks & regards
DG
Please share show interface status  switches.
Please mention which ports are connected between 9300 and CBS 350
Dear Sir,
at 9300 side tw1/1/1 and cbs350 side 1/0/22 connected .
but at 9300 side showing error disable .
C9300 side :- Twe1/1/1 err-disabled 1 auto auto unknown
CBS350 side :- NAME: "TenGigabitEthernet1/0/22" DESCR: "SFP-10Gbase-CX1"
PID: SFP-H10GB-CU10M VID: V01 SN: TED2114H861
Waiting for you reply...
Thanks & Regards
DG
9300 side tw1/1/1
config t
interface TwentyFiveGigE1/1/1
udld port aggressive
cbs350 side 1/0/22
config t
interface TenGigabitEthernet1/0/22
show udld tw1/1/1
show udld TenGigabitEthernet1/0/22
It seems Cable issue. Can you change the cable and check.
Hamed Fazel
By default BPDU guard in enabled on interfaces in 9300 and maybe that cause the error-disabled.
configure that interface by below command
spanning-tree bpduguard disable
shut
no shut
Dear Team,
We have try to do same on c9300 interface side but no change got error disable.
Current configuration : 126 bytes
switchport mode trunk
spanning-tree bpdufilter enable
end
Thanks & Regards
DG
Hello
Is that spanning-tree error disabled?
if so try the following--------with caution.
int x
shut
no shut
Kind Regards
Paul
Dear Team,
end
Thanks & Regards
DG
please show the status of the interface with below command.
show interface TwentyFiveGigE1/1/1 switchport
Dear Team,
Please check below output for your reference.
Switch#sh interfaces tw1/1/1 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Vepa Enabled: false
App Interface: false
Appliance trust: none
Thanks & Regards
DG
You may consider to issue the "show interfaces status err-disabled" command to check the actual reason why your Twe1/1/1 is err-disabled.
Best regards,
Antonin
Dear Team,
Please check below output for your referrence.
Switch# sh interfaces status err-disabled
Port Name Status Reason Err-disabled Vlans
Twe1/1/1 err-disabled gbic-invalid
Thanks & Regards
DG
Put this command under the interface it is hidden command so type it all.
service unsupported-transceiver
Shut
No shut
Thanks for the feedback. Your Cat9300 clearly does not like this SFP+ DAC. When checking the Cisco compatibility matrix (https://tmgmatrix.cisco.com/) it shows the longest passive DAC supported for C9300 is 5 meters (SFP-H10GB-CU5M), for 10 meters it requires the active DAC (SFP-H10GB-ACU10M - still copper but containing electronics).
Provided your SFP-H10GB-CU10M is not Cisco-sourced, it MAY be active in actual fact but not coded so. For that case please check your IOS XE version. The SFP-H10GB-ACU10M support should be since: IOS XE 16.8.1 for C9300-NM-2Y,
IOS XE 16.5.1 for C9300-NM-8X, IOS XE 17.1.1 for C9300-NM-2Q.
Otherwise you MAY consider to play with the "service unsupported-transceiver", "no errdisable detect cause gbic-invalid", etc. commands.
Good Luck!
Best regards,
Antonin
