Cisco understanding etherchannels
fibernet570
I have an etherchannel between a Cisco 6513 and Cisco 4948.  I see the load unevenly distributed, is this reason to be concerned?  Does my ethernchannel need to be tweaked?  I want all three interfaces on my Port-channel evenly distributed, see below the output on my Cisco 6513 named Cisco_111 and Cisco 4948 named Cisco_804.  Please let me know if I have any reason to be concerned.
Cisco_111
Cisco_111#show etherchannel 8 detail
Group state = L2
Ports: 3   Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol:    -
Minimum Links: 0
                Ports in the group:
Port: Gi1/7
Port state    = Up Mstr In-Bndl
Channel group = 8           Mode = On      Gcchange = -
Port-channel  = Po8         GC   =   -         Pseudo port-channel = Po8
Port index    = 0           Load = 0x49        Protocol =    -
Age of the port in the current state: 652d:09h:57m:57s
Port: Gi1/8
Port index    = 1           Load = 0x92        Protocol =    -
Age of the port in the current state: 651d:21h:49m:56s
Port: Gi7/2
Port index    = 2           Load = 0x24        Protocol =    -
Age of the port in the current state: 0d:16h:45m:40s
                Port-channels in the group:
Port-channel: Po8
Age of the Port-channel   = 652d:10h:17m:14s
Logical slot/port   = 14/6          Number of ports = 3
GC                  = 0x00000000      HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =    -
Fast-switchover     = disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     49     Gi1/7    On    3
  1     92     Gi1/8    On    3
  2     24     Gi7/2    On    2
Time since last port bundled:    0d:16h:45m:40s    Gi7/2
Time since last port Un-bundled: 0d:18h:01m:30s    Gi7/2
Last applied Hash Distribution Algorithm: Fixed
Cisco_111#show int gig 1/7
GigabitEthernet1/7 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0111.11f7.3d7e (bia 0111.11f7.3d7e)
  Description: to 8th floor switch, pending specifics
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 2/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is LH
  input flow-control is off, output flow-control is on
  Clock mode is auto
  Last input 00:00:19, output 00:00:09, output hang never
  Last clearing of "show interface" counters 1y35w
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 10442000 bits/sec, 4698 packets/sec
  5 minute output rate 3017000 bits/sec, 2064 packets/sec
     33229354426 packets input, 9610692825893 bytes, 0 no buffer
     Received 13373857086 broadcasts (448935947 multicasts)
     0 input errors, 0 CRC, 2 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     47867286847 packets output, 14899264756853 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier, 5837 PAUSE output
Cisco_111#show int gig 1/8
GigabitEthernet1/8 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0111.11f7.3d7f (bia 0111.11f7.3d7f)
  Clock mode is auto
  Last input 00:00:17, output 00:00:40, output hang never
  Input queue: 0/2000/1/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 8033000 bits/sec, 3128 packets/sec
  5 minute output rate 3981000 bits/sec, 1025 packets/sec
     39489248888 packets input, 11322830685429 bytes, 0 no buffer
     Received 17821844289 broadcasts (617308881 multicasts)
     0 input errors, 0 CRC, 0 frame, 1 overrun, 0 ignored
     27487472499 packets output, 16430125751662 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 9614 PAUSE output
Cisco_111#show int gig 7/2
GigabitEthernet7/2 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0111.baba.ab79 (bia 0111.baba.ab79)
     reliability 255/255, txload 11/255, rxload 4/255
  Media-type configured as SFP connector
  Clock mode is auto
  Last input 00:00:39, output 00:00:06, output hang never
  5 minute input rate 17781000 bits/sec, 5121 packets/sec
  5 minute output rate 43268000 bits/sec, 5137 packets/sec
     111982051 packets input, 40245236643 bytes, 0 no buffer
     Received 103528126 broadcasts (102240560 multicasts)
     78147717 packets output, 70641896104 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
Cisco_804
Cisco_804#show etherchannel 8 detail
Group state = L2
Protocol:    -
                Ports in the group:
Port: Gi1/45
Channel group = 8           Mode = On/FEC          Gcchange = -
Port index    = 0           Load = 0x00            Protocol =    -
Age of the port in the current state: 49d:17h:02m:47s
Port: Gi1/46
Port index    = 1           Load = 0x00            Protocol =    -
Port: Gi1/47
Port index    = 2           Load = 0x00            Protocol =    -
Age of the port in the current state: 00d:16h:46m:04s
Port-channel: Po8
Age of the Port-channel   = 49d:17h:02m:47s
Logical slot/port   = 11/8          Number of ports = 3
GC                  = 0x00000000
Protocol            =    -
  0     00     Gi1/45   On/FEC             0
  1     00     Gi1/46   On/FEC             0
  2     00     Gi1/47   On/FEC             0
Time since last port bundled:    00d:16h:46m:04s    Gi1/47
Cisco_804#show int gig 1/45
GigabitEthernet1/45 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is 0111.0c0c.f06c (bia 0111.0c0c.f06c)
     reliability 255/255, txload 2/255, rxload 1/255
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLH
  input flow-control is on, output flow-control is off
  Last input 00:00:14, output never, output hang never
  5 minute input rate 3023000 bits/sec, 2065 packets/sec
  5 minute output rate 10506000 bits/sec, 4723 packets/sec
     52696526831 packets input, 18338637710503 bytes, 0 no buffer
     Received 22981475103 broadcasts (204563236 multicast)
     4 runts, 0 giants, 0 throttles
     4 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     33632581601 packets output, 9752747146782 bytes, 0 underruns
Cisco_804#show int gig 1/46
GigabitEthernet1/46 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is 0111.0c0c.f06d (bia 0111.0c0c.f06d)
  Last input 00:00:03, output never, output hang never
  Last clearing of "show interface" counters 12w5d
  5 minute input rate 3884000 bits/sec, 1027 packets/sec
  5 minute output rate 8029000 bits/sec, 3119 packets/sec
     7323736082 packets input, 4572076921687 bytes, 0 no buffer
     Received 218840988 broadcasts (55201181 multicast)
     10042206453 packets output, 2381759504055 bytes, 0 underruns
Cisco_804#show int gig 1/47
GigabitEthernet1/47 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is 0111.0c0c.f06e (bia 0111.0c0c.f06e)
     reliability 255/255, txload 4/255, rxload 10/255
  Full-duplex, 1000Mb/s, link type is auto, media type is No Gbic
  Last input 00:00:29, output never, output hang never
  5 minute input rate 42661000 bits/sec, 5089 packets/sec
  5 minute output rate 17610000 bits/sec, 5104 packets/sec
     76975168 packets input, 70652288330 bytes, 0 no buffer
     Received 3290385 broadcasts (3004895 multicast)
     3 runts, 0 giants, 0 throttles
     3 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     110786089 packets output, 40179245257 bytes, 0 underruns
Mn
Hi Manny,
You will not see even load-sharing between each member-links even when you have recommended port configuration. Because load-sharing is done on per-flow basis instead per-packet basis.
EtherChannel load-sharing between each member-link is pre-computed based on hash that resulted from different "input", 6500 supports wide range of L2 to L4 load-sharing input mechanics.More the flows and higher the granular load-sharing method you use, better the load-sharing across each paths. So depending applications running in your network, you can adjust default load-sharing from global configuration mode to acheive best results.
There are some recommendation documented in design guide that you may leverage...
http://www.cisco.com/en/US/docs/solutions/Enterprise/Campus/Borderless_Campus_Network_1.0/Borderless_Campus_1.0_Design_Guide.pdf
thanks,
rahul.
IAN WHITMORE
Level 4
Level 4
I don't think you have reason to be concerned.
Take a look at this document that explains it a little bit and gives you the options. Maybe you would prefer to balance by another method that more evenly distributes the load. You can even test which link the traffic would go over.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
HTH,
Ian
Rahul Kachalia
The best-practice and recommendation to bundle
number of member-links is 2, 4, 8 in single L2 or L3 EtherChannel. This is because it allows system internally to load-share traffic based on number of buckets. Refer to Figure 2-28/Chapter 2 in following design guide.
thanks,
rahul.
Hi Rahul,
I have another Cisco 6513 that is using two Port-channels, should I see even traffic distribution across the GbE?  Both Port-channels have only two members.
Cisco_6513-01#show etherchannel 9 detail
Group state = L2
Ports: 2   Maxports = 8
Protocol:    -
Minimum Links: 0
                Ports in the group:
Port: Gi1/3
Channel group = 9           Mode = On      Gcchange = -
Port-channel  = Po9         GC   =   -         Pseudo port-channel = Po9
Port index    = 0           Load = 0x55        Protocol =    -
Age of the port in the current state: 187d:03h:10m:06s
Port: Gi1/4
Port index    = 1           Load = 0xAA        Protocol =    -
Age of the port in the current state: 187d:03h:10m:05s
Port-channel: Po9
Age of the Port-channel   = 187d:03h:12m:20s
Logical slot/port   = 14/2          Number of ports = 2
Protocol            =    -
  0     55     Gi1/3    On    4
  1     AA     Gi1/4    On    4
Time since last port bundled:    187d:03h:10m:06s    Gi1/4
Cisco_6513-01# show int gig 1/3
GigabitEthernet1/3 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 1234.5678.acf2 (bia 1234.5678.acf2)
  MTU 9216 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 5/255, rxload 2/255
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input 00:00:18, output 00:00:56, output hang never
  Last clearing of "show interface" counters 18w4d
  5 minute input rate 10796000 bits/sec, 6025 packets/sec
  5 minute output rate 22198000 bits/sec, 4975 packets/sec
     106849876679 packets input, 16836142458883 bytes, 0 no buffer
     Received 1308120958 broadcasts (1171259400 multicasts)
     26657285211 packets output, 10715422683700 bytes, 0 underruns
Cisco_6513-01# show int gig 1/4
GigabitEthernet1/4 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 1234.5678.acf3 (bia 1234.5678.acf3)
  Clock mode is auto
  Last input 00:00:04, output 00:00:00, output hang never
  5 minute input rate 42993000 bits/sec, 10472 packets/sec
  5 minute output rate 17921000 bits/sec, 7509 packets/sec
     171942012970 packets input, 48877528708260 bytes, 0 no buffer
     Received 205673779 broadcasts (175882802 multicasts)
     46595096154 packets output, 15289314372580 bytes, 0 underruns
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#show etherchannel 3 detail
Group state = L2
Protocol:    -
Minimum Links: 0
                Ports in the group:
Port: Gi1/1
Channel group = 3           Mode = On      Gcchange = -
Port-channel  = Po3         GC   =   -         Pseudo port-channel = Po3
Age of the port in the current state: 187d:03h:11m:49s
Port: Gi1/2
Port-channel: Po3
Age of the Port-channel   = 187d:03h:14m:03s
Logical slot/port   = 14/1          Number of ports = 2
Protocol            =    -
  0     55     Gi1/1    On    4
  1     AA     Gi1/2    On    4
Time since last port bundled:    187d:03h:11m:49s    Gi1/2
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#show int gig 1/1
GigabitEthernet1/1 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 1234.5678.acf0 (bia 1234.5678.acf0)
     reliability 255/255, txload 19/255, rxload 9/255
  Clock mode is auto
  Last input 00:00:24, output 00:00:32, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 1202
  5 minute input rate 36635000 bits/sec, 30792 packets/sec
  5 minute output rate 75164000 bits/sec, 33229 packets/sec
     381293528598 packets input, 50631274870168 bytes, 0 no buffer
     Received 164927275 broadcasts (71285751 multicasts)
     461344193757 packets output, 78326994017321 bytes, 0 underruns
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#
Cisco_6513-01#show int gig 1/2
GigabitEthernet1/2 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 1234.5678.acf1 (bia 1234.5678.acf1)
     reliability 255/255, txload 7/255, rxload 9/255
  Clock mode is auto
  Last input 00:00:27, output 00:00:36, output hang never
  5 minute input rate 37252000 bits/sec, 29125 packets/sec
  5 minute output rate 30744000 bits/sec, 30383 packets/sec
     327187221784 packets input, 50275217402001 bytes, 0 no buffer
     Received 569975840 broadcasts (60010920 multicasts)
     418724694610 packets output, 47401321074291 bytes, 0 underruns
-Manny
Hi Manny,
thanks,
rahul.
