Cisco vPC vs Stack
Hi Cisco Community ,
Need to know whether in Cisco vPC are the interfaces shown as if in a single chassis when logged in to Mgmt IP ?
I have configured two Nexus 93108 chassis with vPC between them and vPC is successful , but unlike Cisco Stack I have to login on particular Chassis to configure its Interfaces .
Whereas in Cisco Stack We used to login the Mgmt Ip and it automatically took us to the Master unit. Need a clarification whether I am missing something or is it the default behaviour in vPC that Interfaces can not be seen in a consolidated manner?
Thanks in advance .
Hassan Shah
Mark Malone
single devices you will see when you log in to the MGMT ip  , so if you have 2 7ks and you log in either MGMT ip address it will bring you to that 7K only , its not like VSS or a stack
As already noted by Mark, Nexus vPC do not form one logical device, so there's still two distinct devices to manage.
However, I recall there's an option to keep some configuration information in sync between two vPC devices.  I recall it applies to shared FEX interfaces.
Thanks Mark and Joseph for the clarification 🙂
