cisco WS-C3750X-48P
HAMZA NISAR
I got very effective response last time, as i just entered in this field now I'm facing another issue which is I have cisco WS-C3750X-48P switch. now when i try to assign ip to any physical port or when i try to make any port as a third layer i got message: Command rejected: not allowed on this interface.
What i exactly want to do, i want to make different vlans, then need to assign ip to ports and then ip routing after that need to active dhcp relay. please i need urgent help as my management pushing me to perform and i know that this is because of the license but if there is another way kindly let me know. Switch version, and other details I'm gonna mentioned below.
Switch>show version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 18:14 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
Switch uptime is 3 minutes
System image file is "flash:/c3750e-universalk9-mz.122-55.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: lanbase
License Type: Permanent
Next reload license Level: lanbase
cisco WS-C3750X-48P (PowerPC405) processor (revision K0) with 262144K bytes of memory.
Processor board ID FDO1649X0WP
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 44:03:A7:7E:8D:00
Motherboard assembly number : 73-12553-08
Motherboard serial number : FDOSEKWLGG
Model revision number : K0
Motherboard revision number : A0
Model number : WS-C3750X-48P-L
Daughterboard assembly number : 800-32727-03
Daughterboard serial number : FD938JSUVBN
System serial number : FDESLHDKUBU
Top Assembly Part Number : 800-31324-07
Top Assembly Revision Number : B0
Version ID : V04
CLEI Code Number : COMJDFEWLW
Hardware Board Revision Number : 0x04
Switch Ports Model SW Version SW Image
* 2 54 WS-C3750X-48P 12.2(55)SE5 C3750E-UNIVERSALK9-M
Configuration register is 0xF
10 Replies 10
Leo Laohoo
Assign the IP address to a VLAN.
Assign the port to that VLAN.
HAMZA NISAR
Thanks leo but still I've some doubts.. do vlans can communicate with each other without routing protocol as well as can i assign static route to vlans? ? and apart from that can i use ip-helper in lanbase license? I've one doubt regarding below it just showing labase and ip services features why not reflecting ip base feature...
Look at the picture carefully. It says the IP Services Evaluation license is present. Most importantly it says "Not in Use" because "EULA not accepted".
Loe thanks for the confirmation but this I already know what i'm asking I guess in my switch there is no ipbase service feature that is why it is not showing there.. and please if you can clarify me these..
1: Do vlans can communicate with each other without routing protocol as well as can i assign static route to vlans?
2: Can i use ip-helper in lanbase license?
Yes
IP Base or IP Services.
If i understood right you mean ipbase and ipservices vlans can communicate with each other not lanbase. Right.
IP Base and IP Services can do routing.
LAN Base is only Layer 2 (LAN).
I believe that the answer depends on the version of software you are running. According to Cisco documentation "Static IP routing for manually building a routing table of network path information. Starting with Cisco IOS Release 12.2(58)SE, the LAN Base feature set also supports static IP routing on SVIs for 16 user-configured routes." See this link for further details
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_2_se/configuration/guide/3750x_cg/swintro.html
Rick
You have Lan base License :
As per Feature navigator the Lanbase supported feature you looking to do.(attached Excel for your reference)
BB
kindly recheck the file i believe you have attached wrong file instead of lanbase you have attached ip base..
