Clean vty session does not work
Steven Foo
We have a C3850 switch and I could see 2 vty sessions hanging for sometime now.
sh users
    Line       User       Host(s)              Idle       Location
   1 vty 0                idle                     1w5d       hp22-840
   2 vty 1                idle                    2d16h       h11-840g2
*  3 vty 2                idle                 00:00:00      hp2-840
I tried to use the following command to clear it, however it still hang there.
clear tcp line 1
clear tcp line 2
There is only 1 session ESTAB when I issue the command below.
sh tcp brief
There is another 2 line with (state) CLOSED.
8928CB88  157.165.161.38.23          hp22-840.com.49980 CLOSED
8901FC40  157.165.161.38.80          hp11-840g2.com.64926 CLOSED
I tried to issue the following command line, however after that the session is till there.
clear tcp tcb 8928CB88  clear tcp tcb 8901FC40
Any more ideas how do I get rid of the hang sessions?
Does it have any performance impact in long run?
We want try to avoid to reboot the switch if possible as it is running production.
Thank you.
Leo Laohoo
clear line 1 <ENTER>
same, the hanging sessions are still there. this is weird.
