CLI equivalent commands for Smartport Roles
cco
I wonder if anyone was able to find any kind of reference or document for the CLI equivalent commands for the GUI smartport roles on the cisco catalyst 500 express switch? I have searched a lot but didn't find anything.
Thanks in advance,
5 Replies 5
royalblues
Level 10
Level 10
Cisco catalyst 500 series do not support CLI
From the FAQ
http://www.cisco.com/en/US/products/ps6545/products_qanda_item0900aecd80322b09.shtml
Narayan
Thanks for the reply. Yes I know that the Cisco catalyst 500 series do not support CLI. In other words, my question is: what are the (equivalent) set of command(s) applied on the 500 switch when applying a certain smartport role to the switch port using the GUI?
Well I'm asking because knowing the exact configuration applied using the smartport roles will help us in troubleshooting connectivity issues for the 500 series switches.
You may try the following:
http://10.10.10.10/exec
Use this where 10.10.10.10 is the ip of your catalyst express switch. This sort of allows you to issue cli-like commands to the switch, and allows you to see what the configuration is. I'm not sure if this will help or not. What you can actually do here is also very very limited.
That was very helpful. Thanks for the info
