CLNS tunnel : GRE vs EON
Dears
Would like your assistance please regarding below
I want to configure tunnel for carrying CLNS traffic over IP network. I found 2 ways and I wonder whats the difference between them. Whats the pros/cons of each method or which one to use ?
Method one (tunnel mode eon)
interface Tunnel1
no ip address
clns router isis
isis circuit-type level-1
tunnel source Loopback1
tunnel destination 10.0.0.1
tunnel mode eon
Method two (tunnel mode gre)
interface Tunnel1
no ip address
clns router isis
Many Thanks
Sherif Ismail
Any thoughts ?
The encapsulation mode for the tunnel interface defaults to generic route encapsulation (GRE), so this command is considered optional. However, if you want a mode other than GRE, you must configure it by using the following command in interface configuration mode
tunnel mode eon.
EON, a standard for carrying CLNP over IP networks
EON is acronym for Experimental OSI (Open System Interconnection) Network
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Many Thanks :)
Sent from Cisco Technical Support Android App
