Combining two LAN cables' bandwidth as one
siewwei2004
Hi there
My switch is Catalyst 6509. I have 2 ADSL modem-routers that has 1M download speed each. I would like to "combine" both download speed so that I get 2M.
Each ADSL modem-router connects to end PC using LAN cable. Is it possible to connect two LAN cables from the two modemrouters to the switch, and then configure the switch to "combine" the two LAN cables as one (consolidate their speed)? We can then connect one "output" cable to the endstation so that that particular endstation can have 2M download speed.
Is this something to do with load balancing? I need some guidance as to how this can be done.
Thanks a lot! :)
5 Replies 5
Roberto Salazar
Level 8
Level 8
This is not a supported configuration for etherchannel (combining FE or GigE interface to create a bigger pipe) . Etherchannel must terminate on a single device and that device must also support channeling. I am not 100% certain that multi-link can do this either.
Please rate all posts.
devang_etcom
Level 7
Level 7
you can achive it using the Multilink configuration, following link gives you nice examples of T1 multilink just go through it so you can have idea...
http://www.cisco.com/univercd/cc/td/doc/product/aggr/10000/10ksw/mlppos.htm
rate this post if it helps
regards
Devang
laurentElens
Maybe you should have a look at the HSRP.
http://www.cisco.com/warp/public/619/hsrpguidetoc.html
regard
in addition to the other posts, there are routers available with multiple WAN ports, which let you achieve load balancing/sharing, one of them being the Draytek Vigor 300. If you are interested, have a look at this link:
Draytek Vigor 3300 Series
http://www.draytek.com.au/products/Vigor3300.php
GNT
sangvak
I think it's all 'bout the fuction that combine the two DSL line as one serial line.
you could check the other way with new device.
It' might be easy way if you want to change router to NLB(*network load balancer)
http://www.piolink.co.kr/english/product/piolink_series_d.asp
