Comcast Business Static IP to Cisco to Firewall
chueymtz
I am trying to setup my router to sla so that when my comcast isp is down my secondary ip will take over. I am having issues because my comcast although I pay for 5 static ip's I am unable to put into bridge mode per comcast. I'm not sure what I would need to use for wan and static route for it to work. The static ip's i have from comcast are 70.91.x.65-69 with .70 being the gateway. How do I go about setting this up to my cisco port? This cisco is before the firewall so the static ip's are configured in the firewall. Any ideas or has anyone had an issue like this? I asked comcast for the wan ip but they tell me to use the gateway of .70 which doesn't work.
can you more elaborate and share topology
MHM
chueymtz
Here is what I have keep in mind the comcast port 1/0/2 isn't working, I can't get comcast to work going thru this edge router and it can not be put in bridge mode.
Comcast ISP
Static IP's: 70.x.x.65-69 /29
Subnet Mask: 255.255.255.248
Per Comcast use 70.X.X.70 as gateway
HQ_9300_EDGE#sho run
Building configuration...
Current configuration : 12056 bytes
! Last configuration change at 20:01:20 UTC Wed Jan 17 2024
license boot level network-advantage addon dna-advantage
diagnostic bootup level minimal
redundancy
mode sso
crypto engine compliance shield disable
transceiver type all
monitoring
track 1 ip sla 1 reachability
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
shutdown
negotiation auto
interface GigabitEthernet1/0/1
description to ISP to Firewall
no switchport
ip address 4.x.x.169 255.255.255.248
interface GigabitEthernet1/0/2
description Comcast
no switchport
ip address 70.x.x.67 255.255.255.248
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
description connection to Internet Circuit
no switchport
ip address 4.x.x.142 255.255.255.252
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface TenGigabitEthernet1/1/5
interface TenGigabitEthernet1/1/6
interface TenGigabitEthernet1/1/7
interface TenGigabitEthernet1/1/8
interface FortyGigabitEthernet1/1/1
interface FortyGigabitEthernet1/1/2
interface TwentyFiveGigE1/1/1
interface TwentyFiveGigE1/1/2
interface AppGigabitEthernet1/0/1
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 4.x.x.141 track 1
ip route 0.0.0.0 0.0.0.0 70.x.x.70
ip sla 1
icmp-echo 4.x.x.141 source-interface TenGigabitEthernet1/1/1
frequency 5
ip sla schedule 1 life forever start-time now
route-map ISP2 permit 10
match ip address 101
match interface GigabitEthernet1/0/2
route-map ISP1 permit 10
match interface GigabitEthernet1/0/1
control-plane
service-policy input system-cpp-policy
!^C
I am not clear on your topology, can you post a schematic drawing that shows the connections ?
