01-29-2023 10:22 AM
How can be edit the pre configured BGP AS number using DCNM in Fabric without removing the configuration or removing the Fabric.
01-29-2023 11:42 AM
what are you looking edit BGP mean changing the BGP ?
check below guide :
01-30-2023 01:23 AM
I have created Fabric in DCNM with BGP AS number 65534 but now i need to edit this BGP AS number as 64911 to make the iBGP with some other L3 device which have BGP configured with AS 64911.
01-30-2023 01:35 AM
So as i understand you looking to replace BGP with new BGP number, that will be Service intruptive, so where ever you have old AS replace with new, at the same time - peers also required to change new AS number.
01-30-2023 01:40 AM
How can be replace using DCNM. When i am trying to edit the BGP AS number from Fabric setting in DCNM its trying to create new BGP AS but not replacing old.
01-30-2023 02:04 AM
I will check your require
01-17-2024 01:39 PM
01-29-2023 12:56 PM
You can tell the BGP process to use another AS number besides the global AS number, usually used for migrations.
-David
01-30-2023 01:26 AM
I have created Fabric in DCNM with Nexus 9K BGP AS number 65534 but now i need to edit this BGP AS number as 64911 to make the iBGP with some other Nexus 5K device which have BGP configured with AS 64911. Once all services migrated to 9K from 5K we will decommission the 5K.
