Command for Switch port
Khundmir4cisco
I want to lock the switchport in such a way that it only allow one end device to be connected and no two more devices are connected using a AP or another switch or a hub. I don't want to reserve MAC address for the switchport. Instead, I just want to make sure only one end device is connected irrelevant of Mac.
acampbell
If you are going to connect a device to your switch port via another switch you will need to allow
at least 2 mac to attach as the switch or AP will have a mac too.
Something like this (depending on swith type and IOS)
interface fast 0/10
description *** MY SECURE PORT ***
switchport mode access
switchport access vlan 10
switchport port-security
switchport port-security max 2
no shut
Hope this helps
Alex
Regards, Alex. Please rate useful posts.
acampbell
interface fast 0/10
no shut
Hope this helps
Alex
