communication between 192.168.0.0 and 192.168.1.0
Sihanu N
How communication between two office in two different place is possible without changing the IP Range.
Ton V Engelen
Level 3
Level 3
Hi, you ll need static routes or a dynamic routing prot to exchange traffic between 2 subnets.
But you have a network overlap though, so you ll need to do something about that
192.168.0.0/16 overlaps 192.168.1.0/24
maybe you mean 192.168.0.0/24 and 192.168.1.0/24
Then basicly something like
switch 0
ip route 192.168.0.0 0.0.0.255
switch 1
ip route 192.168.1.0 0.0.0.255
This is the actual situation.
192.168.0.0 network contains 300 pc  also in 192.168.1.0 network contains 200 pc
Hi Sihanu,
Maybe you will need some solution like the one in  the following link:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f30.shtml
Best regards,
Alex
*Please rate helpful posts.
bunjiega
what are the subnet masks? You could possibly do NAT between the two if you couldn't immediately change IP addresses.
