07-20-2022 09:05 PM
Dear experts,
When config VSS between 2 switch 6500, Do i need 2 link physical port 10G between 2 switch or only 1 link and what is role of link like management,control, or keep alive, or send data
Please help me!!
Solved! Go to Solution.
07-20-2022 09:45 PM
check below guides. you need min 2 links for VSL and 1 for DAD
http://www.labminutes.com/blog/2013/09/cisco-4500-4500x-6500-vss-configuration
07-20-2022 09:41 PM
The heartbeat link can be a 1 Gbps link.
The cross-link, ideally, should be multiple 10 Gbps links.
07-20-2022 09:45 PM
