configuration multicast packet forwarding on 3750
teymur azimov
Hi dears
I have one server which run some application for wireless user. this server forward multicast  packet to wireless user. server and wlc physically connect to cisco 3750 switch.i want the server forward the multicast packet to wireless users.
server access vlan 4.
wlc controller have 2 vlan: 90 and 110.
and wireless user some of vlan 90 and some of vlan 110.
i enable igmp snooping on wireless controller. and enable globally command but it is not working.which additional configuration i need on cisco switch.
Switch(config)# ip igmp snooping
please help me.
16 Replies 16
Edison Ortiz
Please refer to the documentation on how to configure 'multicast routing' on a 3750 switch:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_58_se/configuration/guide/swmcast.html
Hi thank you reply for me. is it possibly provide me a certain configuration for my network topology.
thank again
Switch(config)# ip multicast-routing distributed
Switch(config)# interface vlan 90
Switch(config-if)# ip pim sparse-dense-mode
Switch(config)# interface vlan 110
thank you very much
do i need ip igmp snooping command on global mode?
do i need some config on server port on sw?
snooping is enabled by default on cisco switches.
no config is needed at the physical port facing the server since the config is applied to the vlan associated to the switchport.
john kennedy
Edison offered some great baseline configuration for multicast routing on one router, however, you should really learn a bit about multicast and IGMP before doing any sort of multicast deployment. It is one of those protocols that can just kill your network.
İ did it but it is not working. i describe the topology.
i have some application running  one pc which is forwarding multicast packet. and this pc connected wireless network with vlan 90. i want to vlan 90 and vlan 110 wireless users can use this application.
int the same vlan which is vlan 90 the wireless user can used this application but  the vlan 110 wireless user can not used.
i did as you wrote me but it is not help me.
can i do some config wlc?
what i need to do on swicth?
Hello Teymur,
You may find the following link about multicast and WLC interesting:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807cc10d.shtml
HTH,
Alex
this guide is not help me.
i also do pim on AP vlan, mgmt vlan but the problem is same. the vlan 90 is working but vlan 110 is not working.
CoreSwitch#show ip igmp snooping vlan 90
Global IGMP Snooping configuration:
IGMP snooping              : Enabled
IGMPv3 snooping (minimal)  : Enabled
Report suppression         : Enabled
TCN solicit query          : Disabled
TCN flood query count      : 2
Last Member Query Interval : 1000
Vlan 90:
IGMPv2 immediate leave              : Disabled
Explicit host tracking              : Enabled
Multicast router learning mode      : pim-dvmrp
CGMP interoperability mode          : IGMP_ONLY
CoreSwitch#show ip igmp interface vlan 110
Vlan110 is up, line protocol is up
  Internet address is 172.30.110.1/24
  IGMP is enabled on interface
  Current IGMP host version is 2
  Current IGMP router version is 2
  IGMP query interval is 60 seconds
  IGMP querier timeout is 120 seconds
  IGMP max query response time is 10 seconds
  Last member query count is 2
  Last member query response interval is 1000 ms
  Inbound IGMP access group is not set
  IGMP activity: 2 joins, 0 leaves
  Multicast routing is enabled on interface
  Multicast TTL threshold is 0
  Multicast designated router (DR) is 172.30.110.1 (this system)
  IGMP querying router is 172.30.110.1 (this system)
  Multicast groups joined by this system (number of users):
      224.0.1.40(1)  239.255.1.1(1)
CoreSwitch#
CoreSwitch#show ip igmp snooping mrouter
Vlan    ports
  90    Router
110    Router
125    Router
CoreSwitch#
CoreSwitch#show ip igmp membership
Flags: A  - aggregate, T - tracked
       L  - Local, S - static, V - virtual, R - Reported through v3
       I - v3lite, U - Urd, M - SSM (S,G) channel
       1,2,3 - The version of IGMP, the group is in
Channel/Group-Flags:
       / - Filtering entry (Exclude mode (S,G), Include mode (G))
Reporter:
       - last reporter if group is not explicitly tracked
       /      - reporter in include mode, reporter in exclude
Channel/Group                  Reporter        Uptime   Exp.  Flags  Interface
*,239.255.1.1                  172.30.110.1    00:18:05 02:04 2LA    Vl110
*,239.255.1.1                  172.30.125.217  00:18:44 01:59 2A     Vl125
*,239.255.255.250              172.30.90.121   00:03:13 01:58 2A     Vl90
*,239.255.255.246              172.30.90.121   00:00:43 02:16 2A     Vl90
*,224.0.1.40                   172.30.110.1    00:19:03 02:04 2LA    Vl110
CoreSwitch#
CoreSwitch#show ip igmp groups
IGMP Connected Group Membership
Group Address    Interface                Uptime    Expires   Last Reporter
239.255.1.1      Vlan110                  00:19:38  00:02:29  172.30.110.1
239.255.1.1      Vlan125                  00:20:17  00:02:27  172.30.125.217
239.255.255.250  Vlan90                   00:04:46  00:02:29  172.30.90.121
224.0.1.40       Vlan110                  00:20:36  00:02:33  172.30.110.1
i configurated 239.255.1.1 on wlc.
and my confuguration on sw:
interface Vlan90
description Wireless
ip address 172.30.90.1 255.255.255.0
end
interface Vlan110(voip wireless)
ip address 172.30.110.1 255.255.255.0
ip igmp join-group 239.255.1.1
end
interface Vlan125 (AP vlan)
ip address 172.30.125.1 255.255.255.0
end
i could not solve the problem.
CoreSwitch#ping 239.255.1.1
Sending 1, 100-byte ICMP Echos to 239.255.1.1, timeout is 2 seconds:
Reply to request 0 from 172.30.110.1, 9 ms
Reply to request 0 from 172.30.125.1, 9 ms
is this configuration correct?
What is your wireless controller version?
7.0
