Configure 1841 w/wic1-ADSL with Centurylink static IP
kbroman
Pleas help.  I have searched for days, through all documents I can get my hands on.
I am trying to configure my 1841 router to connect to my DSL over POTS from Centurylink.  I have a static IP.  I have contacted tech support with Centurylink and obtained all the info I could from them.
The following is from my show run:
interface ATM0/0/0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0/0.1 point-to-point
no snmp trap link-status
pvc 8/35
  pppoe-client dial-pool-number 1
interface Dialer0
ip address 69.68.120.6 255.255.255.128
no ip redirects
no ip unreachables
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip tcp adjust-mss 1440
dialer pool 1
no cdp enable
ip route 0.0.0.0 0.0.0.0 Dialer0
When I show the interfaces, they all show up and a reliability of 255/255 yet I cannot ping my ISP gateway.  When I show route, it shows that the 69.0.0.0 network is directly connected.
I know the connection is good.  When I plug the POTS line into the old modem provided by Centurylink, I get connectivity.  I am trying to get rid of the ISP provided modem and just go through my own router into the rest of my network
I am just lost.  Everything I check says it should be connected, yet, I have no connectivity.  I am aware that the wic is not capable of higher speed dsl connections, but, that should just limit my speed, correct?  I have a HWIC on the way.
The greatest trick the Devil ever played, was to convince the world he did not exist.
morinack64
Level 4
Level 4
Hi Kevin,
Not sure if you completed this battle.
I had to order a DSL modem from CenturyLink (at $6.99/mo) to get the service up and running.
Tech support was about as handy as 2 dead flies.
Once i used their "approved" modem LCP came up and PPP negotiation completed.
I believe it is their pvc they used that got it running. Tech support could not tell me that.
I was them able to take some of the info from their modem and finalize my config and get my 1760 online with the new service. I will now work on returning the leased modem.
Below is my final configuration;
Building configuration...
Current configuration : 2467 bytes
version 12.4
hostname DSL_Router
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console notifications
aaa new-model
aaa authentication login default local-case
aaa session-id common
clock timezone CST -7
clock summer-time MDT recurring 1 Sun Mar 2:00 2 Sun Nov 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
ip multicast-routing
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface ATM0/0
no ip address
load-interval 30
atm ilmi-keepalive
hold-queue 224 in
pvc 0/32
interface FastEthernet0/0
description Local LAN Home
ip address 172.16.17.1 255.255.255.0
no ip unreachables
ip nat inside
ip tcp adjust-mss 1452
ip policy route-map clear-df
speed auto
full-duplex
interface Dialer0
description DSL
mtu 1492
ip address ( ip address negotiated is used for dynamic)
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp chap refuse
ppp pap sent-username password 0
ip forward-protocol nd
no ip http server
ip nat inside source list 1 interface Dialer0 overload
ip access-list extended FILTER
deny   udp any any eq 79 tftp 135 netbios-ns snmp 1434 netbios-ss netbios-dgm 445 389
deny   tcp any any eq ftp finger www 135 139 445 593 1433 4444 389
permit ip any any
access-list 1 permit 172.16.0.0 0.0.255.255
access-list 101 permit ip any any
snmp-server context mmi
snmp-server manager
no cdp run
route-map clear-df permit 10
match ip address 101
set ip df 0
control-plane
line con 0
exec-timeout 90 0
logging synchronous
line aux 0
line vty 0 4
exec-timeout 90 0
privilege level 15
password cisco
end
and sh version
Cisco IOS Software, C1700 Software (C1700-SY7-M), Version 12.4(18a), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Mon 24-Mar-08 03:05 by prod_rel_team
ROM: System Bootstrap, Version 12.2(4r)XL, RELEASE SOFTWARE (fc1)
DSL_Router uptime is 37 minutes
System image file is "flash:c1700-sy7-mz.124-18a.bin"
Cisco 1760 (MPC860P) processor (revision 0x200) with 59432K/6104K bytes of memory.
Processor board ID VMS06220EJJ (2577666991), with hardware revision BB67
MPC860P processor: part number 5, mask 2
1 FastEthernet interface
1 ATM interface
32K bytes of NVRAM.
16384K bytes of processor board System flash (Read/Write)
Good Luck,
Brian
