04-25-2011 07:59 AM - edited 03-06-2019 04:46 PM
need help in configuring vPC on my nexus5K .
04-25-2011 08:57 AM
trying to configure vPC on nexus 5K running into issues.
PeerLink
Nexus5KA-----------------Nexus 5KB
Nexus2KA Nexus2KB
Cisco Load Balancer
Need to connect my cisco load balancer interfaceGi1/1 -- interface Ethernet138/1/2 on nexus 2KA
InterfaceGi1/2---interface Ethernet138/1/2 on nexus 2KB
need to configure vPC for the making load Balancer highly redundant
Here is the config i had on my 5Ks,able to create a peer link and flex fabric ,but running into issues with vPC
Nexus 5K A:
vpc domain 2
role priority 100
system-priority 100
peer-keepalive destination 10.18.168.72 source 10.18.168.71
interface port-channel101
description PPPPPPPPPP-Eth 1/1, Eth 1/2-PPPPPPPPPPPPP
switchport mode trunk
vpc peer-link
switchport trunk allowed vlan 1,10,200
spanning-tree port type network
speed 10000
interface port-channel110
vpc 110
switchport trunk allowed vlan 200
interface Ethernet1/1
description PortChannelPortChannel 5kb 1/1,1/2 PortChannelPortChannel
switchport trunk allowed vlan 10,200
channel-group 101 mode active
interface Ethernet1/2
fex 138
pinning max-links 1
description FEX0138
interface Ethernet1/38
fex associate 138
switchport mode fex-fabric
interface Ethernet138/1/25
description connection ace1
channel-group 110 mode active
Nexus5KB:
vpc domain 2
role priority 200
system-priority 100
peer-keepalive destination 10.18.168.71 source 10.18.168.72
vpc peer-link
speed 10000
vpc 110
switchport trunk allowed vlan 817
description PortChannelPortChannel 5ka 1/1,1/2 PortChannelPortChannel
fex 138
pinning max-links 1
description FEX0138
fex associate 138
description ace connection
ACE : this what I configured
vpc 110
interface gigabitEthernet 1/1
description conn to nex2kA
no shutdown
interface gigabitEthernet 1/2
description conn to nex2kB
no shutdown
05-10-2011 06:56 AM
5KA:
vpc 110
5KB:
vpc 110
ACE :
vpc 110
5KA config does not look right. The port cahnnel will not come up. Please change that and confirm.
Shelley.
05-13-2011 05:32 AM
Shelly
vPC is working on the nexus ,But a question as ,Do I need to unable vPC on ACE
ACE :
vpc 110
As still now I was only configuring ,Please advise ,why do I need to unabe vPC on my ACE
ACE :
05-13-2011 05:44 AM
Basically vPC is like joining multiple interfaces into 1 port channel which spans multiple chassis. This creates a virtual port cahnnel. On the ACE as both links are on the same chassis vPC is not required. That can be a standard port channel.
I overlooked that config on the ace and should be removed as well.
Shelley.
05-13-2011 06:51 AM
Shelly
Somehow my vpc-peer link is not coming up,this is the config I have for peer-link
NexusA
vrf context management
vlan 1,101-105,201-202,300,400-403,501-502
spanning-tree vlan 1,101,103,105,201,401,403,501 priority 24576
spanning-tree vlan 102,104,202,300,400,402,502 priority 28672
vpc domain 1
role priority 1
system-priority 100
peer-keepalive destination 161.247.134.31
interface port-channel139
interface Ethernet1/39
description s0adcdmzsw1b
channel-group 139 mode active
interface Ethernet1/40
NexusB
spanning-tree vlan 1,101,103,105,201,401,403,501 priority 28672
spanning-tree vlan 102,104,202,300,400,402,502 priority 24576
vpc domain 1
role priority 2
system-priority 100
peer-keepalive destination 161.247.134.30
speed 10000
description s0adcdmzsw1a
s0adcdmzsw1a# sh vpc peer-keepalive
vPC keep-alive status : Suspended (Destination IP not reachable)
--Send status : Failed
--Receive status : Failed
--Last update from peer : (21018844) seconds, (849) msec
vPC Keep-alive parameters
--Destination : 161.247.134.31
--Keepalive interval : 1000 msec
--Keepalive timeout : 5 seconds
--Keepalive hold timeout : 3 seconds
--Keepalive vrf : management
--Keepalive udp port : 3200
--Keepalive tos : 192
05-13-2011 07:02 AM
vPC peer keepalives are not passing through.
I dont see the default route configured for vrf management :
ip route 0.0.0.0/0 161.247.134.254 (assuming that is your default gateway)
try that and then ping the 161.247.134.31
ping 161.247.134.31 vrf management
and see if you get pings through. if you do, your vpc peer link will be up (show vpc and show vpc role)
Shelley.
05-13-2011 07:15 AM
Shelly
Another question ,do I need to add
switchport mode trunk allowed vlan 1,101-105,201-202,300,400-403,501-502
vpc peer-link
on the po139 ,do I need to or ,these 2 commands are optional
05-13-2011 07:41 AM
You should have the "vpc peer-link" command on the link between nexus5kA and nexus5kB. This should not be there on the links between the n5k's and the ACE.
For the allowed vlan;s , that is up to you and what vlan;s you want to pass through the peer-link.
Shelley.
