Configuring ASA-5506X for use with Cable Modem
Joshua Smick
I recently obtained an ASA-5506X for my home lab.  I don't have a lot of firewall experience, and I'm trying to connect out to the internet using the ASA.  The ASA is directly connected to a cable modem, and a 2901 router on the inside.  The ASA can ping out to the internet, and the the router (and the rest of the LAN) can ping the firewall, but cannot get out to the internet.  This is the configuration I'm using:
: Hardware:   ASA5506, 4096 MB RAM, CPU Atom C2000 series 1250 MHz, 1 CPU (4 cores)
ASA Version 9.5(1)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface GigabitEthernet1/1
 nameif outside
 security-level 0
 ip address dhcp setroute
interface GigabitEthernet1/2
 nameif inside
 security-level 100
 ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet1/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/5
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/6
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/7
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/8
 shutdown
 no nameif
 no security-level
 no ip address
interface Management1/1
 management-only
 no nameif
 no security-level
 no ip address
ftp mode passive
object network obj_any
 subnet 0.0.0.0 0.0.0.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
 nat (any,outside) dynamic interface
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
user-identity default-domain LOCAL
http server enable
no snmp-server location
no snmp-server contact
service sw-reset-button
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
no ssh stricthostkeycheck
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.0.5-192.168.0.254 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
dynamic-access-policy-record DfltAccessPolicy
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
What am I doing wrong?
5 Replies 5
Perhaps it's just wrong testing. Did you test anything other than PING?
For using PING, you have to enable icmp-inspection:
  inspect icmp
Hmmm, that didn't work.  Could it be something on the router?
You tell us that the router and the LAN can ping the ASA but you do not tell us whether they are pinging the ASA inside interface or outside interface. My guess is that they are pinging the inside interface (which is an address in their subnet) and that if they attempt to ping the outside interface that it would fail. This leads me to guess that the router does not have a default route with the firewall as the next hop.
Rick
Rick
I am able to ping the inside interface.  The outside interface is going to a cable modem on the ASA.  I am able to ping the outside interface on the router as well, but I can't ping anything past that.
I have the following route to the firewall:
ip route 0.0.0.0 0.0.0.0 192.168.0.1
You topology is the following?
Internet ----- ASA ----- c2901 ----- LAN
Then the ASA needs a route to your inside LAN:
route inside NET MASK NEXT-HOP
Where NET/MASK is your internal LAN and NEXT-HOP is the IP of the c2901 in the 192.168.0.0 network.
