Configuring EIGRP on frame-relay
CSCO12190447
Community Member
I used a router as a frame-relay , but the interface serial 0/0 protocol is always down , could any one please help me out
here is the config for it
Building configuration...
Current configuration : 1318 bytes
version 12.4
hostname FR
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 15
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
frame-relay switching
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay
serial restart-delay 0
clock rate 115200
frame-relay intf-type dce
frame-relay route 102 interface Serial0/1 201
frame-relay route 103 interface Serial0/2 301
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
clock rate 115200
frame-relay route 201 interface Serial0/0 102
interface Serial0/2
no ip address
clock rate 115200
frame-relay route 301 interface Serial0/0 103
interface Serial0/3
no ip address
shutdown
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
13 Replies 13
mahmoodmkl
Level 11
Level 11
r u using this as a frame relay switch
if yes thn the config is different for this
no i am using a 2600 router , and when i shutdown the serial interface it comes up for like 10 sec and then its down again
In addition to what John and Peter suggested, make sure you are only clocking the DCE site.  To know which side is DCE, do a "sh cont s0/0"
If it is on older serial interfce, the clock rate usually is 64000
Are you connecting the routers back to back using a DTE, DCE cable?
Hello Mahmood,
Why do you believe so? The configuration of the router as a Frame Relay switch as posted here is perfect. I see nothing wrong with it. The clock rate is a little curious (what kind of Serial interfaces is being used here?) but otherwise, the configuration is just fine.
Mostafa, can you post the output of the following commands?
show ip interface brief
show frame-relay pvc
show frame-relay route
show int s0/0
show int s0/1
show int s0/2
Thank you!
Best regards,
Peter
John Blakley
Can you post the other side? Is this in production or a lab, and which interface is up/down? Generally, incorrect encapsulation on either end can cause this problem. If you're doing this in a lab and you have it connected back to back without a frame relay switch in between, you'll need to disable keepalives with "no keepalive" on the serial interfaces on both ends of the link.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
CSCO12190447
Community Member
Hi peter,
here is the output, and thankd in advance
FR#show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES NVRAM  administratively down down
Serial0/0                  unassigned      YES manual up                    down
FastEthernet0/1            unassigned      YES NVRAM  administratively down down
Serial0/1                  unassigned      YES NVRAM  up                    up
Serial0/2                  unassigned      YES NVRAM  up                    up
Serial0/3                  unassigned      YES NVRAM  administratively down down
FR#show frame-relay pvc
PVC Statistics for interface Serial0/0 (Frame Relay DCE)
              Active     Inactive      Deleted       Static
  Local          0            0            0            0
  Switched       2            0            0            0
  Unused         0            0            0            0
DLCI = 102, DLCI USAGE = SWITCHED, PVC STATUS = ACTIVE, INTERFACE = Serial0/0
  input pkts 28            output pkts 47           in bytes 1652
  out bytes 2608           dropped pkts 8           in pkts dropped 8
  out pkts dropped 0                out bytes dropped 0
  in FECN pkts 0           in BECN pkts 0           out FECN pkts 0
  out BECN pkts 0          in DE pkts 0             out DE pkts 0
  out bcast pkts 0         out bcast bytes 0
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
  switched pkts 24
  Detailed packet drop counters:
  no out intf 0            out intf down 0          no out PVC 0
  in PVC down 0            out PVC down 8           pkt too big 0
  shaping Q full 0         pkt above DE 0           policing drop 0
  pvc create time 01:19:50, last time pvc status changed 00:06:16
DLCI = 103, DLCI USAGE = SWITCHED, PVC STATUS = ACTIVE, INTERFACE = Serial0/0
  input pkts 14            output pkts 36           in bytes 736
  out bytes 2284           dropped pkts 2           in pkts dropped 2
  switched pkts 13
  in PVC down 0            out PVC down 2           pkt too big 0
  pvc create time 01:19:54, last time pvc status changed 00:06:21
PVC Statistics for interface Serial0/1 (Frame Relay DCE)
  Local          0            0            0            0
  Switched       0            1            0            0
  Unused         0            0            0            0
DLCI = 201, DLCI USAGE = SWITCHED, PVC STATUS = INACTIVE, INTERFACE = Serial0/1
  input pkts 51            output pkts 24           in bytes 2824
  out bytes 1356           dropped pkts 8           in pkts dropped 8
  switched pkts 47
  pvc create time 01:20:24, last time pvc status changed 00:05:44
PVC Statistics for interface Serial0/2 (Frame Relay DCE)
  Local          0            0            0            0
  Switched       0            1            0            0
  Unused         0            0            0            0
DLCI = 301, DLCI USAGE = SWITCHED, PVC STATUS = INACTIVE, INTERFACE = Serial0/2
  input pkts 38            output pkts 13           in bytes 2372
  out bytes 692            dropped pkts 4           in pkts dropped 4
  switched pkts 36
  in PVC down 0            out PVC down 4           pkt too big 0
  pvc create time 01:20:27, last time pvc status changed 00:05:47
FR#
FR#show frame-relay route
Input Intf           Input Dlci           Output Intf           Output Dlci           Status
Serial0/0       102                     Serial0/1       201                     active
Serial0/0       103                     Serial0/2       301                     active
Serial0/1       201                     Serial0/0       102                     inactive
Serial0/2       301                     Serial0/0       103                     inactive
FR#show interfaces serial 0/0
Serial0/0 is up, line protocol is down
  Hardware is PowerQUICC Serial
  MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
  Encapsulation FRAME-RELAY, loopback not set
  Keepalive set (10 sec)
  Restart-Delay is 0 secs
  LMI enq sent  15, LMI stat recvd 0, LMI upd recvd 0
  LMI enq recvd 475, LMI stat sent  456, LMI upd sent  0, DCE LMI down
  LMI DLCI 1023  LMI type is CISCO  frame relay DCE
  FR SVC disabled, LAPF state down
  Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0
  Last input 00:00:04, output 00:07:02, output hang never
  Last clearing of "show interface" counters 01:21:10
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 115
  Queueing strategy: weighted fair
  Output queue: 43/1000/64/115 (size/max total/threshold/drops)
     Conversations  2/3/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1158 kilobits/sec
     665 packets input, 10562 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     63 packets output, 2036 bytes, 0 underruns
     0 output errors, 0 collisions, 8 interface resets
     0 unknown protocol drops
     0 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
FR#show interfaces serial 0/1
Serial0/1 is up, line protocol is up
  LMI enq sent  0, LMI stat recvd 0, LMI upd recvd 0
  LMI enq recvd 488, LMI stat sent  488, LMI upd sent  0, DCE LMI up
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 01:21:23
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     539 packets input, 9168 bytes, 0 no buffer
     512 packets output, 8500 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
FR#show interfaces serial 0/2
Serial0/2 is up, line protocol is up
  Last input 00:00:09, output 00:00:09, output hang never
  Last clearing of "show interface" counters 01:21:32
     527 packets input, 8729 bytes, 0 no buffer
     502 packets output, 7857 bytes, 0 underruns
CSCO12190447
Community Member
Hi john ,
Here is the other side
HQ#show run
Current configuration : 1265 bytes
version 12.4
hostname HQ
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
interface Loopback1
ip address 10.1.1.1 255.255.255.0
interface Loopback2
ip address 10.1.2.1 255.255.255.0
interface Loopback3
ip address 10.1.3.1 255.255.255.0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
ip address 172.16.124.1 255.255.255.248
no ip split-horizon eigrp 25
frame-relay map ip 172.16.124.1 102
frame-relay map ip 172.16.124.2 102 broadcast
frame-relay map ip 172.16.124.3 103 broadcast
no frame-relay inverse-arp
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
router eigrp 25
network 10.1.0.0 0.0.255.255
network 172.16.0.0
no auto-summary
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
EAST#show run
Current configuration : 1237 bytes
version 12.4
hostname EAST
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
interface Loopback1
ip address 10.2.1.1 255.255.255.0
interface Loopback2
ip address 10.2.2.1 255.255.255.0
interface Loopback3
ip address 10.2.3.1 255.255.255.0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
ip address 172.16.124.2 255.255.255.248
frame-relay map ip 172.16.124.1 201 broadcast
frame-relay map ip 172.16.124.2 201
frame-relay map ip 172.16.124.3 201 broadcast
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
router eigrp 25
network 10.2.0.0 0.0.255.255
network 172.16.0.0
no auto-summary
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
EAST#
WEST#show run
version 12.4
hostname WEST
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
interface Loopback1
ip address 10.3.1.1 255.255.255.0
interface Loopback2
ip address 10.3.2.1 255.255.255.0
interface Loopback3
ip address 10.3.3.1 255.255.255.0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
ip address 172.16.124.3 255.255.255.248
frame-relay map ip 172.16.124.1 301 broadcast
frame-relay map ip 172.16.124.2 301 broadcast
frame-relay map ip 172.16.124.3 301
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
router eigrp 25
network 10.3.0.0 0.0.255.255
network 172.16.0.0
no auto-summary
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
WEST#
I didn't see anything wrong in the config. Is this in GNS by chance? I copied your configs and pasted them in gns on my end and everything worked without me modifying anything. I'd save the configs and reload gns if that's the case:
HQ#ping 172.16.124.2
Sending 5, 100-byte ICMP Echos to 172.16.124.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/36/44 ms
HQ#ping 172.16.124.3
Sending 5, 100-byte ICMP Echos to 172.16.124.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/31/44 ms
HQ#
HQ#sh ip eigrp neigh
IP-EIGRP neighbors for process 25
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
1   172.16.124.2            Se0/0            157 00:01:21 1248  5000  0  5
0   172.16.124.3            Se0/0            161 00:03:10   68   408  0  3
FR#sh ip int brie
Serial1/0                  unassigned      YES NVRAM  up                    up
Serial1/1                  unassigned      YES NVRAM  administratively down down
Serial1/2                  unassigned      YES NVRAM  up                    up
Serial1/3                  unassigned      YES NVRAM  up                    up
HTH,
John
CSCO12190447
Community Member
Thank you so much john , restarting GNS3 actullay worked
i have one more question am sorry, why cant i ping the loopback networks ? .
HQ#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     172.16.0.0/29 is subnetted, 1 subnets
C       172.16.124.0 is directly connected, Serial0/0
     10.0.0.0/24 is subnetted, 3 subnets
C       10.1.3.0 is directly connected, Loopback3
C       10.1.2.0 is directly connected, Loopback2
C       10.1.1.0 is directly connected, Loopback1
I'm not sure unless you're not waiting long enough for the frame to come up and eigrp to converge. Here's what I see:
HQ#sh ip route
     10.0.0.0/24 is subnetted, 9 subnets
D       10.3.1.0 [90/2297856] via 172.16.124.3, 00:03:38, Serial0/0
D       10.2.1.0 [90/2297856] via 172.16.124.2, 00:00:16, Serial0/0
D       10.3.3.0 [90/2297856] via 172.16.124.3, 00:03:38, Serial0/0
D       10.2.2.0 [90/2297856] via 172.16.124.2, 00:00:16, Serial0/0
D       10.3.2.0 [90/2297856] via 172.16.124.3, 00:03:40, Serial0/0
D       10.2.3.0 [90/2297856] via 172.16.124.2, 00:00:18, Serial0/0
HQ#
CSCO12190447
Community Member
Is there anthing i should i haven't done ? , and the question is why is it working for you but not me however we have the same config files ?
CSCO12190447
Community Member
Everything works now , Thank you so much for helping me out and sorry for wasting you time
You didn't waste our time at all. Come back if you need anything else and glad we could help 🙂
