Configuring EtherChannel Using NME-16ESW
ashishsehgal
Hi Folks,
While configuring L3 EtherChannel on NME 16ESW module I am not able to get "Channel-Group 1 mode on" command.
I am easily able to make L2 EtherChannel.  I am using 12.4 (12) IOS. Kindly have a look at the below configurations:
R0(config)#int port-channel 1
R0(config-if)#no switchport
R0(config-if)#ip address 10.10.10.10 255.255.255.0
R0(config)#interface range fastEthernet 1/14 - 15
R0(config-if-range)#no switchport
R0(config-if-range)#ch?
% Unrecognized command
R0#sh ver
Cisco IOS Software, 3600 Software (C3640-JK9O3S-M), Version 12.4(12), RELEASE SOFTWARE (fc1)
Kindly advice as to what could be the possible error.
Let me know if I need to provide any other information.
Ashish
m. +91-9902017491
glen.grant
  Looks ok ,I would try and put it on the individual ports instead of using the interface range command and see what happens , could be a bug .
Edison Ortiz
Layer 3 EC is not supported under NM-16ESW
Edison
Each time you rate a CSC   discussion we'll donate $1 to the American Red Cross Haiti fund up to a   maximum donation of $10,000 USD.
https://supportforums.cisco.com/docs/DOC-8895
