Configuring IEEE 802.1x Port-Based Configuration
when we do 802.1x port based configuration, is there any specific authentication settings required on windows client pc.
regards
gopi
6 Replies 6
royalblues
Level 10
Level 10
Generally the EAP type is used as MD-5 Challenge under network properties --> advanced
Narayan
I am trying to enable 802.1x authentication in our lan.... i have document talking about .1x config on the switches, but i was wondering what to be configured on acs server... can u help me on this
gopi
Have a look at this link (Dynamic VLAN Assignment for 802.1x and ACS)
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00805e7a18.shtml#cg3
Narayan
.1x Port based configuration can be used for various purposes.One of the well known use is 80.1x port based authentication.
L2 switch dot1x config
hostname L2SWITCH
aaa new-model
aaa authentication dot1x default group radius
aaa session-id common
ip subnet-zero
dot1x system-auth-control
no file verify auto
--More-- spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport trunk native vlan 10
switchport mode trunk
interface FastEthernet0/2
switchport access vlan 20
switchport mode access
dot1x mac-auth-bypass
dot1x pae authenticator
dot1x port-control auto
dot1x reauthentication
dot1x guest-vlan 40
dot1x auth-fail vlan 50
interface FastEthernet0/3
interface FastEthernet0/4
--More-- !
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
--More-- interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
--More-- no ip address
no ip route-cache
interface Vlan10
ip address 10.10.10.2 255.255.255.0
no ip route-cache
ip default-gateway 10.10.10.1
ip http server
radius-server host 30.30.30.2 auth-port 1645 acct-port 1646 key cisco
control-plane
line con 0
line vty 5 15
end
debug radius authentication
1d03h: RADIUS(00000005): sending
1d03h: RADIUS/ENCODE: Best Local IP-Address 10.10.10.2 for Radius-Server 30.30.3
0.2
1d03h: RADIUS(00000005): Send Access-Request to 30.30.30.2:1645 id 21645/26, len
138
1d03h: RADIUS: authenticator 1D FC CB D1 72 D8 4C B1 - D2 D3 82 15 4C E0 58 31
1d03h: RADIUS: User-Name [1] 14 "0018fe6705bb"
1d03h: RADIUS: User-Password [2] 18 *
1d03h: RADIUS: Service-Type [6] 6 Call Check [10]
1d03h: RADIUS: Framed-MTU [12] 6 1500
1d03h: RADIUS: Called-Station-Id [30] 19 "00-19-30-EE-C0-02"
1d03h: RADIUS: Calling-Station-Id [31] 19 "00-18-FE-67-05-BB"
1d03h: RADIUS: Message-Authenticato[80] 18
1d03h: RADIUS: CC 09 BD 5A 1D 14 5B 85 9C 2D 76 51 49 F0 EB 2D [???Z??[??-vQI
1d03h: RADIUS: NAS-Port [5] 6 50002
1d03h: RADIUS: NAS-Port-Type [61] 6 Eth [15]
1d03h: RADIUS: NAS-IP-Address [4] 6 10.10.10.2
1d03h: RADIUS: Retransmit to (30.30.30.2:1645,1646) for id 21645/26
1d03h: RADIUS: No response from (30.30.30.2:1645,1646) for id 21645/26
1d03h: RADIUS/DECODE: parse response no app start; FAIL
1d03h: RADIUS/DECODE: parse response; FAIL
On ACS
I have created a user name / password with pc mac address "0018fe6705bb". I have also configured a network profile with "Allow Agentless Request Processing" option and the same profile is mapped to the group to which the above mentioned user name is mapped
Problem:
User is not getting authenticated. On Acs am getting hit and log error as Auth failed
hope somebody could help me on this issue
Your radius server at 30.30.30.2 is not responding to the client at 10.10.10.2. Look for access lists on the router between the 2 networks which prevent radius communications. Alternatively move your radius server to the 10.10.10 network.
R
