Configuring Management port in Catalyst 4500-X series
Sivan
I brought a new Catalyst 4500-X switch with 16 SFP+ interfaces. I saw a management interface (Ethernet) on the back side of the switch. I wanted to use that port to connect to my management network (172.20.200.X range) to configure the switch via web interface. I logged in via console, but it shows only the SFP interfaces. Someone please help me to get a static IP for the MGNT port and enable web server and access the switch. Much appreciated.
Mark Malone
off my 45x , the F1 is your MGMT and its under a permanennt VRF
interface FastEthernet1
description MGMT
vrf forwarding mgmtVrf
ip address 172.x.x.x 255.255.254.0
speed auto
duplex auto
ip route vrf mgmtVrf 0.0.0.0 0.0.0.0 172.x.x.x
It wont show it in show ip int bri , only in global conf
luis_cordova
