Nexus 5000 switch and jumbo frames
Kernel-Panic
Hello all, I'll start off with some details:
Cisco Nexus 5010 Chassis ("20x10GE/Supervisor")
System: version 5.2(1)N1(9a)
There is a Nimble device plugged into Eth1/17 which we will use for iSCSI traffic. This interface is in VLAN 80, which has its own layer 3 vlan interface with the IP address being 192.168.80.250.
I want to enable jumbo frames so on the Nimble interface I've enabled Jumbo Frames (9000). On the switch I have entered the global configuration to enable jumbo frames:
policy-map type network-qos jumbo
class type network-qos class-default
mtu 9216
exit
exit
system qos
service-policy type network-qos jumbo
I then set it on the SVI vlan interface:
interface vlan80
mtu 9216
However when I then try to ping the Nimble iSCSI interface (which has an IP address of 192.168.80.248) with a frame size of 9000 I get time-outs:
ping 192.168.80.248 packet-size 9000 c 10
PING 192.168.80.248 (192.168.80.248): 9000 data bytes
Request 0 timed out
Request 1 timed out
Request 2 timed out
Request 3 timed out
Request 4 timed out
Request 5 timed out
Request 6 timed out
Request 7 timed out
Request 8 timed out
Request 9 timed out
But - when I change the SVI vlan interface back to 1500, I can then ping with a 9000 packet size but I do suffer packet loss (with a higher ping count):
TEST-5K-01(config-if)# ping 192.168.80.248 packet-size 9000 c 100
9008 bytes from 192.168.80.248: icmp_seq=0 ttl=63 time=1.555 ms
9008 bytes from 192.168.80.248: icmp_seq=1 ttl=63 time=1.281 ms
9008 bytes from 192.168.80.248: icmp_seq=2 ttl=63 time=1.233 ms
9008 bytes from 192.168.80.248: icmp_seq=3 ttl=63 time=1.285 ms
...remaining pings omitted
--- 192.168.80.248 ping statistics ---
100 packets transmitted, 96 packets received, 4.00% packet loss
round-trip min/avg/max = 1.217/1.825/2.264 ms
show queuing interface ethernet 1/17 shows that MTU 9216 is set.
I've tried different MTU values and anything above 4000 starts to encounter packet loss.
Does anybody know why its behaving like this - is it a switch misconfiguration or does the problem lie on the Nimble side?
Thanks.
11 Replies 11
luis_cordova
Hi @Kernel-Panic ,
According to this guide, this configuration is only for the nexus 7000:
https://www.cisco.com/c/en/us/support/docs/switches/nexus-5000-series-switches/112080-config-mtu-nexus.html
interface vlan80
mtu 9216
 Try removing those parameters
Reza Sharifi
On the 5ks and 6ks, Jumbo frame config is global (It applies to the whole switch) and so the jumbo frame command does not apply to an SVI interface.
Thanks both, I removed the MTU config from the SVI interface and it is now back to the default 1500:
show int vlan80
Vlan80 is up, line protocol is up
  Hardware is EtherSVI, address is  547f.ee68.56bc
  Internet Address is 192.168.80.250/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
However I still getting 4% packet loss when pinging the Nimble storage with a packet-size of 9000
Try this , this is how we have our 5ks enabled for jumbo frames and it works in global config
mtu 9216
multicast-optimize
system qos
Thanks Mark, unfortunately that didn't work, I'm still getting 4-5% packet loss with MTU of 9000
Is the server side set yes ? thats all thats required on the Cisco side to enable Jumbo MTU , we have a large ISCSI storage network attached to some of our 5k DC setups in different regions , this was tested heavily when setup ,we ran through it with TAC , ther maybe something else required on systems end to match ?
Hello again, yes its set on the storage side:
Did you check that it's not a cable issue?
We also run Jumbo on our 5548UP Nexus and don't have any issues.
I suppose its possible but when I ping the iSCSI-B address (which is a different switch and cable) I get the same result.
Weird. Do you see any error counters increasing when doing a show interface ….?
Does the iSCSI Interface show you any statistics on storage side?
There's no increasing error counts on the switch interface; it does behave rather oddly - I've just done a ping with 9000 mtu and as expected it suffered a small percentage of packet loss; I then did the same ping again and it completely failed with all pings timing out and 100% packet loss.
I then did a normal ping without specifying packet size which worked as expected with no packet loss; after that I was able to ping with 9000 MTU but again with a small percentage of packets lost.
I get the feeling this is the Nimble interface.
