Configuring SFLOW on 2960X
I am attempting to setup netflow/sflow on a 2960X and I am currently getting no top talker information on Logic Monitor which I am using. I have attached my switch config am I missing something?
balaji.bandi
Try using different names (instead all LM)
Example :
https://www.balajibandi.com/?p=1383
BB
Jitendra Kumar
thers is a specific requirement with the third party like solar wind or newrelic and they suggest you as well for what exactly they required for the confirm so switch can communicate with the container where it on Linux on prim or on the cloud also- Linux team need to provide such details ip and ports, URL, etc...
The last time i was worked with Newrelic was provided all config details the same I was configured and switched and started sending logs to the container.
Below are the documents generally available for netflow config.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/security/configuration_guide/b_consolidated_152ex_2960-X_cg/b_consolidated_152ex_2960-X_cg_chapter_010110.pdf
Jitendra
Jitendra
