Configuring views on switches
Kelvin Willacey
Level 4
Level 4
Hello all. I need to configure different views on switches for rbac but I am not familiar with it at all and I would much rather use ACS but that's not an option at the moment. I configured a simple single view for testing purposes that would only allow a user to run show commands. All show commands work except a show run. Can anyone say why this is and how to get it working, please see config inline, thanks.
aaa new-model
aaa authentication login default local
aaa authorization exec default local
username cisco privilege 15 secret 5 $1$Vp16$fPi4fThSy3m7eKyJ9tRmE0
parser view showmode
 secret 5 $1$aLV5$oCJaul/qcO5Pmf3O64lAW0
 commands exec include all show
privilege exec level 15 configure terminal
privilege exec level 15 show running-config
privilege exec level 1 show
Naveen Venkateshaiah
Your configuration seems to be fine,
can you try this command to view running config
"show run view full"
check if it displays
Naveen
***Rate if it is helpful***
Naveen
Thanks that worked. Seems cumbersome though.
