Lights on all 3750-X switchs blinking rapidly
wilddoktor-sp
We recently installed 15 of these switches, and we're having a few odd, random network issues. But before I enumerate those issues, I have a simple question: are the connection lights on these switches *supposed* to blink rapidly? Or are they supposed to blink *normally*?
On all other switches I've ever seen / worked on / worked around, when a cable is plugged into a port, the connection lights blink upon network activity. You know what I mean; sometimes they blink a little faster when there's lots of activity, but mostly it's an almost lazy, random kind of blinking.  When you look at a switch and every light on every port that's connected is blinking very rapidly, your first instinct is "No *wonder* nothing works around here!" and you find the port that's chattering and unplug it...all the blinkies go back to normal.
Well, on the 15 switches we've installed, every light that's on blinks rapidly, as if there's an uncontrolled storm going on.
Is that the "new norm"? Did I miss the memo, and there is nothing to be worried about here? Or are the rapidly blinking lights telling me there is, indeed, a problem?
I'll be glad to get into specifics later; I just need to know if this rapid blinking is normal or not.
11 Replies 11
Reza Sharifi
I have installed quite a few 3750-X switches.  I would not worry about the fast blinking light, but I would check the CPU to make sure everything is running smoothly.(sh processes cpu)
I guess the one thing I failed to mention is that all the lights blink at the same time, at the same speed (crazy fast; they almost look solid grean, they're blinking so fast).  So on a switch with 20 connections, 20 lights (even the lights on the fiber ports on the NetFlow modules) all blink crazy fast, at the same time.
Why would every connected port be getting the same amount of traffic at the same time? Isn't that what the lights are saying? Or again, is this by design? (That would be a terrible design, in IMHO...)
I ran across the exact same behavior the other day. My first thought was "Broadcast Storm".
Did you ever resolve this question?
what I can say is - a broadcast storm will affect a site at a given time not all of your branches at once.
pjmonline
A loop? Run wireshark on a computer that is connected to the switch and see if you can see any issue.
All 15 switches in 12 different IDFs are all doing the exact same thing...that would be a big loop. :-) Would certainly explain some of the glitches, of course!
Again, not trying to troubleshoot in this thread; just trying to find out if crazy fast blinking lights is the norm for these switches...
Hi, Bill.
One of our clients at remote site reporting the similar problem, just wondering how is your case ended? thanks.
Leo Song
schaef350
Do a this command on one of the interfaces you would expect only a small amount of traffic on: sh interfaces <interface> | inc 5 minute
Convert bits to megabites and see how much traffic it actually is.
clear counter <interface>      would set all counters to 0 and you could check immediately after clearing to see if an unruly number or multi or broadcasts are being counted.  If so start tracking down the source...
- Be sure to rate all helpful posts
Parvesh Paliwal
Level 3
Level 3
Can you check LED modes therein:
Table 1-8 Port Mode LEDs
Mode LED
Port Mode
Description
STAT
Port status
The port status. This is the default mode.
SPEED
Port speed
The port operating speed: 10, 100, or 1000 Mb/s.
DUPLX
Port duplex mode
The port duplex mode: full duplex or half duplex.
MAST1
Master
The stack master status.
STACK1
Stack member status
StackWise port status
The stack member status.
The StackWise port status. See the "Stack LED (Catalyst 3750-X)" section.
PoE2
PoE+ or UPOE port power
The PoE+ or UPOE port status.
is there an update ?
Remember marking helpful, if so, please.
Parvesh
billhagen-sp
Wow...old thread. :-)
Thanks for the recent feedback; I will try your suggestions this week and report back.
Also, since we're currently in a flat network topology (no vlans; everything is on the same segment), that could account for the fast blinking.  However, we're currently moving to a vlan structure, so I'm curious to see if that slows the blinking at all.
Will report back when I have some more info.
