Configuring Virtual links in Cisco 3550 switch
gururajtele
I am using a CISCO 3550 Multilayer switch with the
IOS version 12.1(11)EA1. I am configuring
Virutal link with the following commands :
cisc0(config)#router ospf 10
cisco(config-router)# area 1.1.1.1 virtual-link 8.8.8.8 authentication null dead-interval 40 hello-interval 10 retransmitt-interval 5 transmit-delay 2
cisco0(config)#
But the DUT does not make 8.8.8.8 as its neighbour. The area 1.1.1.1 is a transit area.
Kindly let me know whether any other configuration is required
j-block
Level 4
Level 4
A VLAN interface created by using the interface vlan vlan_id global configuration command and by default a Layer 3 interface.
Can you post a brief n/w topology?
What do you see when you do a debug ip ospf adj?
Narayan
is 8.8.8.8 the router-id ? that portion of the command needs to be the router-id, not necessarily the IP address.
