Configuring WS-C2950C-24
kcurry9806
WS-C2950C-24 IOS V12.1(20)EA1. I am trying to configure the vlan to no ip redirects and no proxy-arp with no success. I have tried configuring these settings under interface w/o success either. Does this IOS version not recognize these settings?
these options are available in version 12.1(22)EA9 onward.
If you upgrade to this or higher you should be able to use all these. I have following in my configuration
no ip redirects
no ip unreacheables
no ip proxy-arp
no ip route-cache
Shaheen
glen.grant
Those are layer 3 functions , the 2950 is a layer 2 switch . the svi is used to manage the switch only .
Thank you very much,
Ken
no ip redirects
no ip unreacheables
no ip proxy-arp
no ip route-cache
Shaheen
Thanks Shaheen. So these settings are available in the IOS version 12.1(22)EA9 and later. Do you know is this documented anywhere on the Cisco website?
This is interesting because we just set these variables in a WS-C2962G-24TC-L switch that the CNA identifies as a layer 2 switch also. That switch has version 12.2(25)SEE2 installed.
Ken
