connect 10Gbp/s Port with 1Gbp/s Port
keeran
The Switch CBS350-24XT has 24x 10Gigabit Copper. Does it work with a PC, which support only up to 1Gbp/s ?
balaji.bandi
yes if the device  port support 1G/10G, then it will auto negotiate with PC.
BB
I think u mixed up. The Switch Port supports only 10Gbp/s according to the datasheet. My PC supports only 1Gbp/s. If I connect my PC with this Swithc Port, they can't negotiate, since my PC supports only 1G and Switch Port only 10G.
Honestly, some time Cisco document bit poor.  If you have device then test it ( i have not tested) 10GB Etherent ports some have backward compatability,. cam not give gaurantee that works.
If you have switch and PC you need to test it - If you buying new switch, then requirement is 1GB, then you need look different models.
Note : other post of my reply bit confused, just given input if Auto.
BB
