Connect 2 routers to cable modem
Rich davis II
Hey guys i'm struggling here any help will be greatly appreciated.
i have 2 routers with a switch and pc connected to the switch.
i  am working on RIP and i enabled it on both routers.
my current set up is this:
PC---Switch(3550)---Router2(2610)---Router1(2610)--- Cable modem
I am able to ping from pc to Router1. I am able to ping 4.2.2.2 and google from Router1 but unable to ping it from Router 2 and pc.
Here is my config for Router1:
Current configuration : 1089 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
interface FastEthernet0/0
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Serial0/0
ip address 192.168.20.2 255.255.255.252
ip nat inside
interface Serial0/1
no ip address
shutdown
router rip
version 2
network 192.168.20.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Serial0/0 overload
access-list 1 permit 192.168.0.0 0.0.255.255
control-plane
line con 0
exec-timeout 0 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
login
line vty 5 181
password cisco
login
end
Here is my config for Router2:
Current configuration : 978 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip address 192.168.30.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 192.168.20.1 255.255.255.252
clock rate 64000
interface Serial0/1
no ip address
shutdown
router rip
version 2
network 192.168.30.0
no auto-summary
ip http server
control-plane
line con 0
exec-timeout 0 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
login
line vty 5 181
password cisco
login
end
3 Accepted Solutions
Try to add default route 0.0.0.0/0 to router 2 that points to router 1.
Forgot to mention: you can also add redistribute static to your router rip configuration section.
I think your NAT statement is wrong, serial 0/0 is your internal interface, you should specify fa0/0 in your nat statment if I am not mistaken.
this --> ip nat inside source list 1 interface fa0/0 overload
instead of -->
5 Replies 5
I never did redistribution on a static route. I'll look it up and try it on Friday when I get back home. Thanks for the tips.
I added static redistribution to the rip config and added the ip static route to router 2 and was still unable to ping to outside websites.
instead of -->
