Connected 2 3560 Catalyst switches via fiber. Network acts flakey some VLANs down
linda.blaser1
I have 2 Catalyst 3560 switches.  Several switches in Bldg A, but only one in Bldg B.
I had fiber run between the two buildings.
When I connect the 2 3560's using Fiber/GBIC connectors GLC-SX-MM, the network gets flaky and some of the VLAN even go down.
This is how I have the ports on each end configured:
interface GigabitEthernet0/50
 description ToBuildingX
 switchport mode trunk
 switchport nonegotiate
Any ideas?  I'd appreciate any suggestions.
18 Replies 18
Reza Sharifi
After connecting the 2 switches together, can you post the output of
show spanning-tree?
afpicore3560g-01>sh spanning-tree
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 0
Address 0017.a405.3b40
Cost 20019
Port 48 (GigabitEthernet0/48)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address b414.8929.ec00
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Gi0/48 Root FWD 19 128.48 P2p
Gi0/51 Desg FWD 4 128.51 P2p
Po10 Desg FWD 3 128.136 P2p
VLAN0010
Root ID Priority 32778
Address 0008.30a4.1380
Cost 4
Port 51 (GigabitEthernet0/51)
Bridge ID Priority 32778 (priority 32768 sys-id-ext 10)
Aging Time 300 sec
Gi0/34 Desg FWD 4 128.34 P2p Edge
Gi0/36 Desg FWD 19 128.36 P2p Edge
Gi0/37 Desg FWD 4 128.37 P2p Edge
Gi0/38 Desg FWD 4 128.38 P2p Edge
Gi0/48 Desg FWD 19 128.48 P2p
Gi0/51 Root FWD 4 128.51 P2p
Po4 Desg FWD 3 128.88 P2p
Po5 Desg FWD 3 128.96 P2p
Po6 Desg FWD 3 128.104 P2p
VLAN0100
Root ID Priority 32868
Cost 4
Bridge ID Priority 32868 (priority 32768 sys-id-ext 100)
Aging Time 300 sec
VLAN0104
Root ID Priority 32768
Address a4ba.db8a.b5ed
Cost 8
Port 46 (GigabitEthernet0/46)
Bridge ID Priority 32872 (priority 32768 sys-id-ext 104)
Aging Time 300 sec
Gi0/46 Root FWD 4 128.46 P2p
VLAN0105
Cost 8
Port 47 (GigabitEthernet0/47)
Bridge ID Priority 32873 (priority 32768 sys-id-ext 105)
Aging Time 300 sec
Gi0/47 Root FWD 4 128.47 P2p
VLAN0110
Root ID Priority 32878
Cost 4
Bridge ID Priority 32878 (priority 32768 sys-id-ext 110)
Aging Time 300 sec
Gi0/2 Desg FWD 4 128.2 P2p Edge
Gi0/9 Desg FWD 4 128.9 P2p Edge
Gi0/10 Desg FWD 4 128.10 P2p Edge
Gi0/13 Desg FWD 4 128.13 P2p Edge
Gi0/14 Desg FWD 4 128.14 P2p Edge
Gi0/15 Desg FWD 4 128.15 P2p Edge
Gi0/16 Desg FWD 4 128.16 P2p Edge
Gi0/17 Desg FWD 4 128.17 P2p Edge
Gi0/19 Desg FWD 4 128.19 P2p Edge
Po1 Desg FWD 3 128.64 P2p
VLAN0111
Root ID Priority 32879
Cost 4
Bridge ID Priority 32879 (priority 32768 sys-id-ext 111)
Aging Time 300 sec
Gi0/22 Desg FWD 4 128.22 P2p Edge
Gi0/23 Desg FWD 19 128.23 P2p Edge
Gi0/25 Desg FWD 19 128.25 P2p Edge
Gi0/29 Desg FWD 19 128.29 P2p Edge
VLAN0112
Root ID Priority 32880
Cost 4
Bridge ID Priority 32880 (priority 32768 sys-id-ext 112)
Aging Time 300 sec
VLAN0120
Root ID Priority 32888
Cost 4
Bridge ID Priority 32888 (priority 32768 sys-id-ext 120)
Aging Time 300 sec
Gi0/18 Desg FWD 4 128.18 P2p Edge
Gi0/20 Desg FWD 4 128.20 P2p Edge
VLAN0124
Root ID Priority 32892
Address 00cc.fcfd.d000
Cost 3
Port 136 (Port-channel10)
Bridge ID Priority 32892 (priority 32768 sys-id-ext 124)
Aging Time 300 sec
Gi0/35 Desg FWD 19 128.35 P2p Edge
Po10 Root FWD 3 128.136 P2p
Now mind you, I don't have the two connected cuz I don't want to bring users down again.
Can you provide the show commands when you have a maintenance window and the 2 switches are connected together, so you don't bring down the network?
Here's what I get when they are plugged connected:
(I connected both sides with fiber.
Hurried and did a sh int gi 0/50
Then disconnected before people noticed they were down.  :)
Here's what I got:
afpicore3560g-01#sh int gi 0/50
GigabitEthernet0/50 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is b414.8929.ec32 (bia b414.8929.ec32)
Description: TruckShopSwitch
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
input flow-control is off, output flow-control is unsupported
Last input 00:00:01, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2000 bits/sec, 1 packets/sec
5 minute output rate 2000 bits/sec, 2 packets/sec
34682292664 packets input, 46898058598400 bytes, 0 no buffer
Received 24178074 broadcasts (10471019 multicasts)
0 watchdog, 10471019 multicast, 0 pause input
15558616726 packets output, 3092966805686 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
2412428 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Also, the fiber cables are fixed together so they cannot be swapped.
Am I using the right GBIC Connectors?:  GLC-SX-MM (CNUIAFJAAA)
Hi Linda,
Out of interest, it may be worth you setting both the speed and duplex statically on both switch interfaces. I have seen auto/auto on fibre interfaces cause issues historically.
 I would suggest the following next steps;
1. Statically assign the speed and duplex. In interface configuration mode (in your case Gi0/50 on one switch) type the following commands;
speed 1000
duplex full
[Ensure this is completed on both sides of the trunk]
2. Before enabling the interfaces, please provide a "show spanning-tree" output for both switches (each side for the trunk)
3. Finally, have you configured which VLANs are permitted to use the trunk, or have you allowed all VLANs to traverse the trunk link?
If possible, post running configs from both switches. Based on your postings, it sounds like STP issue.
Thx
MS
Unfortunately, I don't have a maint. window.  We are a 24/7 operation.
Before connect the switch make sure
1 the switch in vtp transparent mode
Thanks for your help but I’m not sure how to do this.
2 make these switches with higher spanning root priority
Would this fix the priority issue:
priority-queue out
3 make sure trunk is up and notice the interface by looking to lights of interface maybe you have a loop in some where
Can’t be a loop since nothing is plugged into the switch in bldg. 2  yet.  Yes, the green lights do come on, on both ends.
Here's what I got:
Keepalive not set
  • Make it as transparent
    • Vtp mod transparent
  • Set spanning tree
    • Spanning-tree vlan (valn numbers) priority? And see the highest number
mattjones03
Hi Linda,
Could you send me the output for the following;
sh int Gi0/50
Would be good to see this from either side of the trunk link.
Both Switches have port 50 configured the same, just the description differs:
afpicore3560g-01#sh run int gi 0/50
Building configuration...
Current configuration : 151 bytes
description TruckShopSwitch
end
Can you provide the output without, the "run" statement.
Oh...gotcha.
Here you go:
GigabitEthernet0/50 is down, line protocol is down (notconnect)
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is 1000BaseSX SFP
Last input 01:22:56, output 01:22:39, output hang never
34682292655 packets input, 46898058594413 bytes, 0 no buffer
Received 24178065 broadcasts (10471010 multicasts)
0 watchdog, 10471010 multicast, 0 pause input
15558616653 packets output, 3092966796971 bytes, 0 underruns
afpicore3560g-01#
