Connecting Cisco router to another Cisco router
tonynsx
I know when connecting similar devices you're suppose to use crossover cables.
My question is, what happens if I use a "normal" cat 5 where both ends are the same?
I'm connecting 2 Cisco 2611 to each other.
unless your IOS supports auto MDIX (which means it detects the connecting cables and logically switches pinouts), a straight cable won't work.
For reference, bookmark the handy guide below:
https://www.computernetworkingnotes.com/ccna-study-guide/cabling-cisco-devices-guide.html
8 Replies 8
How can I check if they support auto MDIX?  Is there a Cisco command?
Tony
I found this, I assume it's the same for a router (if it's available on my Cisco 2611)
Switch# configure terminal
Switch(config)# interface gigabitethernet1/0/1
Switch(config-if)# speed auto
Switch(config-if)# duplex auto
Switch(config-if)# mdix auto
Switch(config-if)# end
Indeed, check for the interface command 'mdix auto'...
2600 routers don't support MDI/MDI-X.
I guess that's why I can't ping the other router?  Plus, no link lights are on even though I have no shut.
I will connect crossover cables.
That's why CCNA courses will always teach the basics of when to use a cross-over and straight-through cable.
So what type of cable is used to connect the routers?
