ā05-19-2016 06:47 AM - edited ā03-08-2019 05:50 AM
I have phisical connection betwen ASA 5510 and routrer 2911 . If I generate some activity in my network , conncection is down, I didnt get any logs in ASDM in ASA and CLI in router , I have " term mon enable" , the only message that I note is increas number of CRC error , If this helps I have IPsec on router over ASA, I check speed, and duplex, I change pachcord many time, reload ASA help only for few hours, I loses connection every few minutes.
ā05-19-2016 07:11 AM
Hi Marcin,
Tried changing cables between ASA and router or ports on ASA and router?
Sheshu.
ā05-19-2016 07:21 AM
Yes , many times
ā05-19-2016 07:24 AM
Losing connection?? Can you please explain a bit? You are losing P2P connection between ASA and router?
ā05-19-2016 07:27 AM
yes , I connect via cable this devices
ā05-19-2016 07:43 AM
ok.. how do they connect? Is there any intermediate transport device or something? or is there any transport vendor?
ā05-19-2016 08:43 AM
no it is directly connection
ā05-19-2016 09:02 AM
You said, you do some activity and it goes down? What exactly you are doing?
Can you please also share show interfaces <int> logs for both ends.
