Connection issues to devices on stacked Catalyst 9200L switches
IlijaZhikovski
Hi everyone,
A few days ago, i changed two WS-C2960-24TT-L switches with two stacked Catalyst 9200L switches.
Ever since i made this change, i noticed that every single device has a really slow connection, i'm losing ping to the devices, SSH is really slow, RDP is really slow etc.
I have 2 uplinks, GigabitEthernet1/1/1 is to our CORE switch, GigabitEthernet2/1/4 to other ACCESS switch.
I tried troubleshooting the switch/ports, but can't come up with an idea what could be the issue.
Here is the output of the 2 uplink ports:
GigabitEthernet1/1/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 3c13.cc5f.ec31 (bia 3c13.cc5f.ec31)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
input flow-control is on, output flow-control is unsupported
Last input 00:00:00, output 00:00:08, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 74
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 3637000 bits/sec, 709 packets/sec
5 minute output rate 1056000 bits/sec, 404 packets/sec
95814614 packets input, 70190377800 bytes, 0 no buffer
Received 11880694 broadcasts (8867720 multicasts)
0 watchdog, 8867720 multicast, 0 pause input
66824525 packets output, 12782824914 bytes, 0 underruns
Output 4969609 broadcasts (0 multicasts)
0 output errors, 0 collisions, 4 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet2/1/4 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 802d.bfed.8434 (bia 802d.bfed.8434)
Keepalive not set
Last input 00:00:15, output 00:00:00, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 7870
5 minute input rate 103000 bits/sec, 65 packets/sec
5 minute output rate 351000 bits/sec, 247 packets/sec
30022847 packets input, 17905254827 bytes, 0 no buffer
Received 7811898 broadcasts (3510541 multicasts)
0 watchdog, 3510541 multicast, 0 pause input
36110786 packets output, 14828748859 bytes, 0 underruns
Output 3778534 broadcasts (0 multicasts)
0 output errors, 0 collisions, 2 interface resets
Could there be an issue with the stacking configuration?
show switch
Switch/Stack Mac Address : 3c13.cc5f.ec00 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch#   Role     Mac Address        Priority Version State
*1          Active    3c13.cc5f.ec00      15         V01 Ready
2           Standby  802d.bfed.8400     14         V01 Ready
show switch stack-mode
Switch# Role      Mac Address       Version     Mode     Configured State
*1         Active    3c13.cc5f.ec00      V01        N+1            None Ready
2          Standby  802d.bfed.8400     V01        N+1            None Ready
Since this is my first time stacking Catalyst 9200L switch, is the Active/Standby Role correct? Is the Mode N+1 correct?
ANY questions or help about this issue would be really appreciated, i will gladly help!
balaji.bandi
As per the output seems to be ok,  i see some drops "Total output drops: 7870"
try adding below command :
qos queue-softmax-multiplier 1200
Also some information we dont have what is the version of Code - how is your configuraiton to uplink is the Layer 2 port-channel ? can you post the configuration both the side if the problem still exisits after issue above command.
also please let us know is the issue connected device to this switch, or from this conencted users to outside ? what is the IP information also helps us.
clear the interface countes and observ any drops  still occuring.
BB
post the output of:
sh buffers
