connectivity between networks problem
andy
Visitor
Network setup:
Router has four interface each connected to a different network ( in this 4 different PCs, each of which is 137.80.xxx.2)
Each router interface is configured as the default gateway with IP addresses of 137.80.xxx.1)
This is as simple a network as it gets but The computers can only ping to the interfaces of the router.  They cannot ping each other.  Additionally, when you turn on debug for icmp, the router never sees the packets when pinging from PC to PC, only when there is a successful ping (such as when a PC pings a router interface.  issue.png
This is also a problem when using these same computers on a switch with IP routing enabled.
This configuration works, of course, in Cisco packet tracer with no issues.  I suspected the computers were the issue, but they can ping their default gateways and the default gateways (interface) of the other networks.
Any insight is greatly appreciated.
Andy
From each PC can you ping all other interface IPs on the router ?
If you can then check all PCs for firewalls.
Jon
11 Replies 11
Reza Sharifi
What  type of switch are you using and what is the license level ("show license" and/or "sh ver")
Also, can you post "sh run" from the switch?
Here is the info:
3925 ipbasek9 (universalk9-m)
and
c2960c universalk9
===--- config ---===
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
interface Loopback1
ip address 137.80.104.1 255.255.255.255
interface FastEthernet0/0
ip address 137.80.100.1 255.255.254.0
duplex auto
speed auto
interface FastEthernet1/0
ip address 137.80.101.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet2/0
ip address 137.80.102.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet3/0
ip address 137.80.103.1 255.255.255.0
duplex auto
speed auto
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Anyone?
Are these the built in interfaces on the 3925 router or are you using a switch module?
When you are on the router, can you ping all the IPs?
Can you post "sh ver"from the router?
 All interfaces are internal interfaces and not the switch card.  Also, I can ping all configured interfaces, just not the computers that are attached.  The router is not on a network so getting the config will take a bit.
Addition... One of the computers can ping another computer.  This is very confusing.
Here is the configuration:
hostname acrtr
boot-start-marker
boot-end-marker
enable secret 5 $1$AOaw$nGua3KFXy7Mdh6oOl9c0S1
no aaa new-model
ethernet lmi ce
no ip domain lookup
ip cef
no ipv6 cef
license udi pid C3900-SPE100/K9 sn FOC183669WR
hw-module sm 1
redundancy
interface Loopback1
interface Embedded-Service-Engine0/0
no ip address
interface GigabitEthernet0/0
description OpsFloor interface
ip address 137.80.100.1 255.255.255.0
duplex full
speed auto
interface GigabitEthernet0/1
description Programmers
duplex auto
speed auto
interface GigabitEthernet0/2
Shop 2nd
duplex auto
speed auto
interface FastEthernet0/0/0
description Configuration Man
duplex auto
speed auto
interface FastEthernet0/0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet1/0
no ip address
shutdown
interface GigabitEthernet1/1
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 100 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
flowcontrol software
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
Can you ping from PC wiith IP 137.80.100.2 to PC with IP 137.80.101.2?
duplex full
speed auto
duplex auto
speed auto
duplex full
speed auto
duplex auto
speed auto
No, but I can ping from PC with IP 137.80.100.2 to PC with IP 137.8.103.2.  The odd part is I cannot ping the other way...from 137.8.103.2 to 137.80.100.2
duplex full
speed auto
to:
duplex auto
speed auto
Jon
Yes. All firewalls have been turned off. Will re-check them all next week.
Was told the F/Ws were turned off... they were not. Thanks for your help.
