Converting CatOS into Cisco IOS
rajinikanth
Level 3
Level 3
I would like to know how can i convert Cat0S on Catalyst 2948G-GE-TX ;
Code Version: 8.4(3)GLX
into Cisco IOS .
6 Replies 6
mohammedmahmoud
Level 11
Level 11
Only the Cat6500 can undergo migration from CatOS to IOS.
HTH,
Mohammed Mahmoud.
Thanks for your response.
Is their a way to allow only http traffic on 2948G-GE-TX switch.
I wanted to convert it into Cisco IOS so that i can use access-list command to allow only port 80 traffic.
Raj
Hi Raj,
Unfortunately i've never worked on a 2948G with CatOS, but i can try looking it out for you.
BR,
Mohammed Mahmoud.
2948-GE-TX is a Layer2 switch and it doesn't understand upper-layer protocols such as http.
You must have a Layer3 switch for application driven ACLs.
Hi Edison
I am able to configure access-list on 2960 Layer2 switch .
I am asking is their any way we can configure access-list on Cat0S switches.
Raj
Hi Raj,
Nops that is not possible on CATOS switches.
Ankur
