Copy firmware from switch to different model switch
bigkeoni64
Hello
Wondering if it is possible to use a Nexus 9K switch as a tftp server to load firmware onto a cat 2960x switch?
In other words, can I push the .binary file to the Nexus 9K then from the Nexus 9K use it as a tftp server to push that .binary fil to a 2960x switch?
WinSCP > Nexus 9K > 2960x in that order.
Thank you
7 Replies 7
I'll check it out. So there would be no issue with putting 2960x firmware onto a Nexus to then push it to a 2960x firmware?
For whatever reason I could not get scp to work on the 2960L to pull the firmware from the Nexus, but I was able to with sftp...interesting.
Thanks for the tip
Glad SFTP worked for you!
you use tftp not USB because of distance ?
That is correct. The Nexus and 2960x and 2960L are in a COLO 100 miles away.
