CoS tagging for Voice
connect101
I'm using IPCommunicator,
How can I tag the voice stream to have a high priority than other application.
There is no IPPhone. There are just Softphone.
Thank you
4rmorris
Check out the SRND for end to end QoS:
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
There are specific examples for tagging traffic from PCs with softphone in there.
Good luck!
Ryan Morris
michaelchoo
AutoQoS has a parameter that allows you to extend the "trust boundary" to the PC. I think the syntax is "auto qos voip cisco-softphone". Problem with this, you have to ensure that you're not running high-bandwidth apps that can also set DSCP values, or you may encounter prioritization issues on your PC's NIC.
